HI, Our washer does everything, fills and empties, electrons work but the drum will not spin, noticed a burning smell just before it conked out. Will I need a new motor and if so will it be a good idea to just buy a new washer. Washer is 9 years old. Thanks a million
  • 44 Answers
Cannot help you without a make and model number.
Posted on Oct 16, 2010
My kitchenaid washer has a burning smell
Hi, a slipping or severed belt will produce a burned rubber smell. A belt supports the drum and ensures its smooth movement. If it wears, the drum's movements weaken and finally come to an abrupt halt. In addition, a slipped or severed belt usually produces a burned rubber smell. Refer to the washing machine manual to review how to locate the belt. If the belt is no longer around the drum's center, shift the belt back to its original position. If rubber fibers are discernible or cracks are apparent, change out the worn belt for a new one.
Thank you.
Jun 05, 2012 | Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
I have a fisher paykel washer that is not drain/spinning properly and I noticed a burning/hot smell. Anything i can do? It is 5 yrs old.
ours did the same thing with the burning smell also. I found that the pump motor kept tripping out from overheating and would not empty the drum thus telling the computer not to spin. I took out the pump and found that the rotor inside the armature had surface rust all around it so i gave it a light sand to clear the rust and whalah...no more tripping out, the pump motor needs to be disassembled to get at the rotor.
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
There was a rubber smell, now washer won't spin.
It is possible that the bearings supporting the drum have seized
Was the machine noisy before it stopped?
If there is tension on the belts and the drum is locked then the motor will spin and burn the belts.
Aug 18, 2009 | GE WBSE3120B Top Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washer just stopped
I would check the drainpump ans see if there is something jammed inside like a coin or screw,nail etc before doing anything else .Unplug the machine first though . A burning smell will occur with a load of water trying to spin .
Nov 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
