Question about JVC AV-27530 27" TV
I accidentally hit the menu button on my tv and seem to have reset something. It goes from Channel 126 directly to Channel 24 and will not set to channel 3, which is the only one that works with my cable
    Top Expert:
  • JVC Master
  • 74,136 Answers
Hello
You have hit the channel skip function to on. Go to menu and come towards functions where you can see channel skip. Keep it to "off" position. Now it is in "on" position.
Posted on Oct 16, 2010
I'm trying to play my Xbox on a Symphonic Tv model
push the av/tv button in the tv panel.
May 03, 2013 | Televison & Video
Need code for dynex television, using a nexxtech 1519000A remote.
Programming with Code Search
1. Manually turn on the device (TV or
Cable box) to be controlled.
2. Press and hold the P (Program) button
until the red indicator stays on. Release
the P button.
3. Press and release the desired mode
button (TV or Cable). The red indicator
blinks, then stays lit.
4. Press the Channel Up button repeatedly
(up to 300 times) until the device to be
controlled changes channels. If you
accidentally overshoot the desired code,
press the Channel Down button to
backtrack through the library until the
device changes channels. Pressing
Channel Up changes the direction to
forward again.
5. Press and release the Enter button to set
the code.
If the device does not have a Channel Up
button, use Power instead. If you go all the
way through the code library without
finding the correct code the indicator blinks
a few times then goes off.
Feb 05, 2010 | Dynex 24" Standard-Definition Digital TV
HOW CAN I RESET THE V CHIP TO UNBLOCK ALL THE RATINGS
Try this procudure from the manual.
Notes (for TV RATING and MPAA RATING):
● You cannot access the setup menu when the
“PROTECTED PROGRAM by ...” message
appears. Move to an unblocked channel
before you hit [MENU].
● When you select a rating and set it to
[BLOCK], the higher ratings will be blocked
automatically. The lower ratings will be
available for viewing.
● When you set the lowest rating to [VIEW],
all other ratings will automatically be available
for viewing.
V-CHIP SET UP
MENU
To exit the menu
[CHANGING THE
Oct 04, 2008 | Durabrand DWT2405 24" TV
Sansui TV, V chip accidentally set
If you are on a protected channel where you are getting the "Protected Program by TV-etc" you have to get out of that channel and go to a channel that is not protected. That will allow you to hit your "Menu" button and access the V-Chip settings on your TV. Depending on the type of TV you have, you may end up using your Vol Up button as a sort of "Enter" button. Hope that helps!
May 24, 2008 | Televison & Video
Tv won't turn on
did you get any help yet with this problem?
Perhaps check out this forum.
http://www.highdefforum.com/showthread.php?t=25246
I think there might be a guy who can help you out with that problem.
Bunky
Mar 29, 2008 | Philips 30PW8420 TV
Sanyo DS31590 channel display
I found the solution to this problem . If someone accidentally hits the recall button the display channel will show on the TV screen, To correct this problem hit the Info Button and the display channel will disapear. This works only if you have the standard cable box. I have another TV that uses a dual mode cable box, tried this procedure with analog RCA TV but it didn't work. Don't know if this procedure will work for all display problems, but it worked for me.
Jan 12, 2008 | Sanyo DS31590 31" TV
Channel set
If you're on cable you need to make sure your set is in the "cable mode". After this you choose from the menu "auto program" or "auto search" and then hit the button on your remote or on the front panel and your set should go through all cahnnels and remember the ones that have a signal on them. Stargazer
Mar 17, 2007 | Durabrand DWT2405 24" TV
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
JVC AV-27530 27" TV Logo
149 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
