Question about Canon L290 Plain Paper Laser Fax
If I want to make a copy, the papersheet stops during process and I van read check the printer ##322
    Guru:
  • Canon Master
  • 452 Answers
##322: problem with the fixing unit:
  1. the fixing unit was not set correctly
  2. remove the fixing unit and check the resistor value if its incorrect replace the fixing unit
  3. else replace PWB
Posted on Oct 16, 2010
All my colored prints have 2 one inch strips of faded color. What do I need to do?
First tray printing a black and white copy to see if you get same quality problem then try each individual color. If it shows on each copy then check The transfer belt Assy . If it only shows on one color then would be a drum unit or could be toner on laser shield glass . Other thing stop it during copying process and see where it's coming from look at drums and see if that shows up on them
Jul 10, 2015 | Ricoh Aficio CL3500N Laser Printer
Papersheet is smashed in the printer. Possible to open and remove the paper?
If you carefully turn to the back of printer you should see locks one either side press pull this should release a dropdown lid allowing access you should find paper awaiting you to gentle yet firmly pull out and clear runners
Nov 01, 2013 | HP Photosmart C6180 All-In-One InkJet...
My printer will not print. diagnostic says it is off line. How do I get connected?
Check with another USB cable, if no result un install the drivers, install once again during the installation system will ask to connect the printer, connect it if its not recognized by the system replace the formatter assm,,,.
Note: Before processing,check printer functionality like copy, menu print..if its OK then only you can do the above said process.
Sep 30, 2011 | HP Photosmart Premium C309A All-In-One...
How i can solve the ricoh 350 error sc-322
hii dear 322 means synchro1 not detected signal that go to sp mode yellow cancel and put 107 and hold on red cancel 3 seconds yo will see copy sp in asquar then put 2109and# and 2108and# and close machine and open if it's not work out try to clean mirrors in laser unit ok
Jan 25, 2011 | Ricoh Aficio 1035 Copier
MITA DC 1460 copier stops
try switching to "manual" exposure setting instead of "auto" call service to check sensor and process control
Jan 06, 2010 | Office Equipment & Supplies
Half of the page is black. This happens during
Is this a printer or MFP? If it copies and scans then your problem is in the scanner area, either something is on the glass or you have a bad CCD (changes image into bits to write info to drum) let me know if this is a 8100DN or what and I will find more info on the scanning section.
Aug 06, 2009 | HP LaserJet 8100 Printer
Dropped coins into papersheet feeder canon pixma mp780
The Canon is not a piggy bank! Even though it does **** money out of your pocket. Have you tried shaking it upside down? Failing this you really need to get a torch and have a GOOD look. If no coin disassembly will be necessary
May 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
Canon L290 Plain Paper Laser Fax Logo
121 people viewed this question
old marine
old marine
