Question about Panasonic DMR-EZ47V DVD Recorder/VCR
DMR-EZ48V is showing that a disc is in unit when there isn't. This ia causing no discs to be read no matter whether it is a bought dvd or recorded dvd-r
  • 597 Answers
The reason the player keeps showing there is a disc in it while there is none is because the lens is either weak or bad, that is why it also keeps showing no disc.
The solution to the problem is either for you to replace the lens or use a lens cleaner to clean the lens.
To replace the lens, all you have to do is to open the unit up with a screwdriver, you will have access to the lens directly, then you can replace it with the new one.
Be very careful in order not to damage any component in the player.
Take care and good luck
Posted on Oct 16, 2010
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DMR-EZ48V does not recognise Sony DVD+RW disks
Hello
If there are some writing errors in data, or sctraches, Sony sets won't read the disc well; especially to DVD+RW discs. OK.
Apr 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
The problem is it says non recordable disc cant read those are the Panasonic discs that came with it how much is a new laser if i need one
I love these sorts of problems. The typical estimated cost to replace the laser (which may also contain the spindle motor in the same block - as one part) and labour including alignment, firmware, etc. is around $200 - $300 approximately at an authorised Panasonic service centre. You would need to take the unit to a repair centre for a quote on the relevant repairs/parts etc., involved. This way you can make a decision as to whether or not to go further.
However, if the discs you got with the recorder are meant to be recordable, and it can't record them, chances are the laser could just be dirty (factory dust if you bought it new or general dust if you got it secondhand) or it may need refocusing/aligning, or the discs are defective.
These are good units, but keep in mind the DMR-E55 is a 2004 model and does not feature a built in HDD or digital tuner - it is not unfixable though. The other thing you can do which is cheaper, as well as using a DVD lens cleaner disc, is to use a different brand of blank DVD-R/RWs - it might not like the discs you got with it. Have you tried different discs? have you tried to play a shop-bought DVD movie in it? if so, does it read the disc?
Try the lens cleaner disc and different blank DVDs first. If neither fixes the issue, consider the above option - take it to a workshop for analysis/quote.
Mar 18, 2011 | Panasonic DMR-E55 DVD Recorder
When I try to record a show. There is no picture on the disc when I'm done. Its just a white noise screen. I finalize the disc too. there is no prompt to tell me to format the disc.
If the disc playes back then the problem is not with the DVD unit. In order to record white noise, the channel selected for record is probably not tuned in. Try recording the same channel on to video tape and see what results you get.
Mar 09, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Cannt play/record DVD's - keep getting "no read" error sfter inserting disk - nothing works - tried brand new discs to record on and even a new movie on disc! How do I correct no read error on...
Depending on the formats of the discs you tried, and assuming they are the correct ones for this machine, it sounds very much like a defective DVD drive and/or software within the unit. If it is under warranty take it to an authorised service agent/workshop for assessment to see if it needs a new drive or not. If it isn't reading any discs, and the unit is brand new, it would most likely be the drive which would be at fault.
Nov 15, 2010 | Panasonic DMR-EZ48VK DVD Recorder
DMR-EZ48V- DVD drive not working
Check Panasonic.com for Firmware updates. If it has a reset button reset it. Take off the cover remove dust and lint, also clean laser eye with rubbing alcohol. DO NOT LOOK DIRECTLY AT THE LASER LENS IF YOU PLUG IT IN, DURING THE OPERATION.
Sep 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
May 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR EZ47V freezes occasionally, will not play certain discs
i hope ,too.if its only months since you bought that ,avail of the warranty package that comes with it.
May 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
334 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
