Question about Denon POA-8300 3-Channel Amplifier
When i tun on my DENON avc-2800 amplifier it comes up with 'protection'. How do i fix this
  • 4,234 Answers
Please see the link below for an explanation of Protect mode. Specific to your model, the output transistors are likely to be shorted. This particular model will shutdown the entire unit if any of the channels have a problem. Without actually seeing the unit and taking some internal measurements, I cannot state for sure the parts required for repair. I would expect a parts cost in the $20-$40 range minimum.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Oct 16, 2010
Hi i have a DENON Amplifier AVC-1000 and want to connect a graphic equlizer is it possable with no receiver.Thanks Scott
A graphic just connects between the tape inputs and outputs of Amps tape in and outs. So yes it is possible to connect one.
Jun 11, 2017 | Denon Audio Players & Recorders
Denon AVR-2800
Hi, This is because your unit goes in to protection mode because of some bad connection in the input/output section .Disconnect your spkrs,inputs..turn the volume is Down all the way and power it up,Check your wiring for shorts at the inputs and outputs. at your service sreejith
Jul 31, 2007 | Denon AVR-2800 Receiver
I have denon avc 2530, now it is showing :Protect: which is i cannot remove, may u help me. ilyasfarhan.dp@gmail.com
There's an overload. Generally caused by a short in the power amp stage. Check the device(s) on the big heat sink.
Feb 18, 2014 | Audio Players & Recorders
I was given a Denon AVC 3020 amp that was connected to a Denon AVR 1082 receiving. The receiver is working fine but I can't seem to reconnect the amp back nor can I use the amp independently from the...
So you want to slave the 3020 to the 1082, right? Use the Pre-outs on the AVR to feed the amp. I imagine the AVR manual, which I cannot find, talks about that.
Jun 19, 2011 | Denon Audio Players & Recorders
Denon avc-3020 amplifier, both rear speakers play the same sound, sounds from the left also play through the right rear speaker and vice versa
You really need to read the manual and maybe physically rearrange your speakers for that left / right swap thing. Back Surrounds (if that's what you meant) frequently are the same unless the origianl program material has 7.1 sound.
How did the Test Tones fare?
http://www.user-manuals.com/user-manual-DENON-AVC3020.html
Mar 16, 2011 | Denon Audio Players & Recorders
When on the stand by button on display come and display showing protect how do i rectify the protect mode?circuit diagram?
protect mode comes on generally when speaker have shorted. disconnect the speakers & try. If it powers on properly try one speaker at a time till you find out which speaker is causing the problem
Dec 23, 2010 | Denon AVR-2800 Receiver
Have a Denon amp (AVC-A11SR) and cannot use the OSD function. Can you give some solutions on how to fix this. Thanks
I have an AVC-A10SE,very similar. The OSD only works via the monitor out COMPOSITE output, so you will need to connect a cable from your amp from this socket to a composite in (yellow) socket on your tv
Dec 18, 2010 | Denon Audio Players & Recorders
Hello DENON AVC-A1SR servicing manual
try
www.servicemanuals.net
Good folks
Jan 20, 2010 | Audio Players & Recorders
DENON AVC-2850
1-check sound input source(dvd -tuner-deck)and confirm that amplifier is assigned to sound source-you must check source with it is cabels.
2-check sound output with it is cabels(speakers).
3-if every thing is fine your amp has a problem and needs to go to service center.
Jan 07, 2008 | Audio Players & Recorders
Denon POA-8300 3-Channel Amplifier Logo
484 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
