Question about Century Wavemaster Training Bag
Hi I bought a Century Wavemaster XXL today.An it's missing the Retaining Locknut.How ? and Where can I buy a Retaining Locknut?
We just bought a used scooter. it uses two batterys. one battery was missing, need too buy new ones how do they get hooked up?
You need two matching batteries and unless you are satisfied that your existing battery is retaining a satisfactory charge you should by two new batteries that are compatible both with your scooter and with the charger. New chargers are not expensive however, a faulty or inappropriate charger may well damage expensive batteries.
Jun 15, 2014 | Pride Health & Beauty
Are UK and Ireland included in the 22 countries on TomTom Classic XXL GPS?
Hi Mike, I would think they should be. I suggest you go to the website and check there. Regards John
Oct 06, 2013 | Troy Lee Designs Troylee Gp Mtb Glove...
1999 buick century instrument cluster resistors loose on board
4 RESISTOR ON RIGHT SIDE >> CHECK SOLDERING >> RESOLDER , IF MISSING THAN GO TO RADIO SHACK & BUY 150 OHM RESISTORS >> INSTALL THEM & PROBLEM SOLVED >> 4.16 5 MIN, + 20 MIN REMOVING & REINSTALLING CLUSTER !!
Jun 24, 2012 | 1999 Buick Century
Remove rear brake drums
Light Duty Models
  1. Raise the vehicle so that the wheel to be worked on is clear of the floor and install jackstands under the vehicle.
  2. Remove the wheel. Remove the three retaining nuts and remove the brake drum. It may be necessary to back off the brake shoe adjustment in order to remove the brake drum. This is because the drum might be grooved or worn from being in service for an extended period of time.
  3. Before installing a new brake drum, be sure to remove any protective coating with brake cleaner or a suitable fast-drying degreaser.
  4. Install the brake drum in the reverse order of removal and adjust the brakes.
Heavy Duty
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel. Loosen the rear brake shoe adjustment.
  3. Remove the rear axle retaining bolts and lockwashers, axle shaft, and gasket.
  4. Remove the wheel bearing locknut, lockwasher, and adjusting nut.
  5. Remove the hub and drum assembly from the axle.
  6. Remove the brake drum-to-hub retaining screws, bolts or bolts and nut. Remove the brake drum from the hub.
To install:
  1. Place the drum on the hub and attach it to the hub with the attaching nuts and bolts.
  2. Place the hub and drum assembly on the axle and start the adjusting nut.
  3. Adjust the wheel bearing nut and install the wheel bearing lockwasher and locknut.
  4. Install the axle shaft with a new gasket and install the axle retaining bolts and lockwashers.
  5. Install the wheel and adjust the brake shoes. Remove the jackstands and lower the vehicle.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
May 08, 2011 | 1991 Ford F250
My tom tom xxl will not turn on. Can you help me please ?
next time you buy a GPS, keep it out of the sunlight. this helps stopping it freezing up. You have fried it. Its no good so throw it away.
Apr 08, 2011 | Tomtom XXL 540S GPS Receiver
I have a tom ton 540m xxl gps that was dropped,The plastic cover over the touch screen is shattered,the touch screen itself is no longer functioning. The gps turns on but I can not get past the 1st screen....
gps have come down in price a whole lot. Always worth going to the manufacture to see how much it would cost to replace the screen. I know radioshack has awesome gps for a little over 100
Apr 06, 2011 | Tomtom GPS XXL 540M LIFETIMEMAPS ...
Since 3 days ago my tomtom XXL 550 TM takes 20 minutes to get traffic updates why
Hi, if its updating with 3G, 3G is very poor at the moment & very unreliable & slow.
Regards
Mark
Jan 07, 2011 | Tomtom XXL 550 Car GPS Receiver
Is toshiba TDP-S8 good projector because I bought it today for $ 300.00 used. Thank you
Toshiba's s8. Designed to deliver stunning images in breathtaking XXL format, the TDP-S8 features 2000:1 contrast, the latest DLP technology for brilliant color and sharpness, and 2000 ANSI lumens brightness for top performance. The product retailed for close to two thousand dollars. Due to problems production was discontinued. If it works for you then you got a good deal. Replacement parts are easily available on ebay.com for reasonable prices.
Jul 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Bobbin tension part missing
Buy a new bobbin case. It is the fastest,easiest way to fix the problem.
sewman7
Aug 28, 2008 | Singer 3116 Simple
Century Wavemaster Training Bag Logo
551 people viewed this question
Top Century Sport & Outdoor - Others Experts
Bill Eager
Are you a Century Sport and Outdoor - Other Expert? Answer questions, earn points and help others
