I have a samsung 13kg diamond drum toploader, my problem is after selecting all relevent options to wash my clothes when the machine start washing the clothes it also drain some water out. My clothes end up not washed properly because the water that the machine drains has detegent on. How can i fix that, i even think i'm not selecting the correct option to wash. Please help.
  • 44 Answers
If the drain hose is pushed too far down the drain pipe, it will have a tendency to to siphon out. Only use 1 or 2 table spoons of detergent as the washer uses very little amounts of water. Read your instruction manual as it says the drain hose has to be higher than a certain height before it goes to the drain.
Posted on Oct 16, 2010
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
Dec 16, 2015 | Samsung Washing Machines
How do i make my samsung diamond washer model WF8500NHW use more water in the drum when washing a load
The amount of water in a washing machine is measured to be the optimal amount. If the clothes do not clean, perhaps you should reexamine the powder.
Feb 14, 2015 | Samsung Washing Machines
Where to clean filters on Samsung 13kg top loader?
Sounds like you need to have your machine looked at by a professional. You should not be finding rubber pieces in the machine.
May 08, 2014 | Washing Machines
Hi, I'm using Panasonic Aquabeat NA-F130T1.(13kg),Fuzzylogic,Toploading. It stops at end of wash mode before rinse and blinks U12 code. Pls advise? Thanks.
Hi there, I'm using Panasonoic F130T1 washing machine.
my problem is,the washing did'nt complete n the water remains in the machine.
Pls advice as how i could solve this problem,tq.
Azhari.
Jan 11, 2013 | Washing Machines
My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
May 25, 2010 | Samsung Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
I have a Samsung SW60ASP toploader and it continues to deposit black 'bits' in the washing machine after use, staining clothes and I have to wash everything again. I have had the drum cleaned, but the...
To overcome the problem, try using hand hot water for your wash once or twice each month, the hot water keeps the inside of the machine clean by not allowing the oily residue from body oils that adhere to your clothes from sticking to the hose etc, also there is always some water left over in the bottom of the bowl (you can't see this water) which has left over scum that has not rinsed away still sitting in this water. GIVE YOUR WASH AN EXTRA DEEP RINSE WHEN THE CYCLE FINISHES.(just turn your dial to where it says RINSE) that way your clothes will be much cleaner and the washer will have removed any left over gung etc from your clothes and bowl etc.. Hope this helps..
Jul 15, 2008 | Samsung Washing Machines
Washing Machines Logo
296 people viewed this question
Top Washing Machines Experts
