Question about Whirlpool AKZ159IX Oven
Have a whirlpool double oven with error message F01 how do i fix it
shaggyrat
  • 1224 Answers
SOURCE: whirlpool double oven
water or over spray in the panel let dry for couple days and turn back on see what happens
Posted on May 09, 2008
  • 10865 Answers
SOURCE: F7 error message in DCS 27in double electric oven
hello. here is the customer service department info at DCS. Since this unis is new, Irecommend that you work directly with them so as to avoid voiding the warranty
http://www.dcsranges.com/contact.html
Posted on Jun 22, 2009
SOURCE: E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Posted on Nov 07, 2009
  • 84 Answers
SOURCE: Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Posted on Nov 09, 2009
  • 84 Answers
SOURCE: whirlpool double ovens error message e6 f2
E6 F2 is always a problem with the control board. It can be fixed quickly and reliably at www.fixyourboard.com
Posted on Nov 03, 2010
Model akz669/ix/04. What does error F01 indicate?
Communication error oven control board
Jan 05, 2016 | Whirlpool Ovens
Oven is displaying F01 complaint. I have no manual to see what this means.
Hello & Welcome to FixYa
F01 error in your whirlpool double oven means a bad electronic control board that needs replacement. Please get back if your need more help.
Kevin
Oct 25, 2011 | Whirlpool RBD305PD Electric Double Oven
Hi - I have a whirlpool gold series electric double oven. The error message is E1 F2. Anyone know how to fix this?
it could be the following
Taking a Quick Look
The E1 F2 error message indicates the control board thinks the touch panel has been unplugged from the board or it cannot read the switches.
How it Works
The panels on these ovens utilizes a switching matrix to constantly monitor all the buttons for a key press. By using a matrix for switch input, many buttons can be read by the processor using very few wires. The unfortunate side of a switch matrix is if any one wire becomes damaged, an entire row of switches on the matrix will no longer be usable since they cannot be seen by the control board.
advise
getting a qualified engineer to check this touch panel and suspect touch panel maybe defective and need replacing.
I hope this was helpful
Jan 05, 2011 | Whirlpool RBD305PD Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Whirlpool double ovens error message e6 f2
good day,
hope this link below will solve your problem.
ovens
Mar 26, 2010 | Whirlpool RBD245PDS Electric Double Oven
F2 error on Whirlpool RBD245PD Double oven
F2 is a bad temperature sensor.
The no lights function is a bad clock control.
Jan 10, 2010 | Whirlpool RBD245PD Electric Double Oven
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Error code E6F2
i got a tech sheet for your range accept this message as a fix ya and e mail me at b4829@yahoo.com and ill send it back as an attachment just say f2 e6 code
May 24, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool AKZ159IX Oven Logo
63 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
