Question about Sony Ericsson K800i Cellular Phone
Configuration settings - Sony Ericsson K800i Cellular Phone
  • 1,188 Answers
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Tip
Wifi Guide For C3 also other phones
<span><b><u> <span><b><u><img src="vhin100889_25.jpg" /><br /></u></b></span>* How to deal with WLAN (WiFi) *</u></b></span> <span><b><u><br /></u></b></span> <span><b>Setting 1:- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Internet connection &gt; Ask first<br /><br />- Goto Menu &gt; Settings &gt; Configuration &gt; Default config. settings &gt; myGlobe (or Smart)<br /><br />- Goto Menu &gt; Settings &gt; Configuration &gt; Preffered access point &gt; myGlobe Internet (or Smart Internet)<br /><br />- Goto Menu &gt; Internet &gt; Web settings &gt; Configuration settings &gt; Configuration &gt; myGlobe Internet (or Smart Internet)<br /><br />- Goto Menu &gt; Internet &gt; Web settings &gt; Configuration settings &gt; Account &gt; myGlobe Internet (or Smart Internet)<br /><br />- Select your preferred scanned network, then Connect.<br /><br />- You will notice a WiFi signal logo ..oo)))) on the top screen indicating you're connected.<br /><br />- Go to MENU &gt; Internet &gt; Go to address <i>(and enter the website you want)</i><br /><br />- Done. Enjoy browsing via WiFi.</b><b><br />Setting 2:- Go to Menu &gt; Settings &gt; Configuration &gt; Personal Settings &gt; Add &gt; Access point (leave others as is) &gt; press back &gt; Option &gt; Activate- Goto Menu &gt; Settings &gt; Configuration &gt; Preferred access point &gt; My access point- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Internet connection &gt; Ask first<br /><br />- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Available WLANs<br /><br />- Select your preffered connection, then connect.</b><b><br />Note:- Update your phone to the latest firmware, preferrably version 7.20 or higher. Firmware upgrade might solve Web browser bugs and WiFi issues.<br /><br />- Check your WLAN server, you might have a weak WiFi signal.</b></span> <span><b><u><br /></u></b></span>
on Jul 12, 2011 | Cell Phones
Nokia s40 "chat server not connected"
If you have Airtel or Tata Docomo as your mobile provider, we have confirmed reports of successfully using WhatsApp with a specific wireless access point configuration:
  1. Go to Settings > Configuration > [Preferred Access Point] > Select Mobile Office.
  2. Go to Settings > Configuration > [Default config. settings] > Delete the config. settings.
  3. Reboot your phone.
If you have Vodafone as your mobile provider, these steps may help:
  1. Go to Settings > Configuration > [Preferred Access Point] > Select Vodafone Mobile Connect.
If you have Idea as your mobile provider, you may be able to successfully use WhatsApp by following these steps:
  1. Go to Settings > Configuration > [Default Config Settings] > Select Idea Internet
  2. Go back to Configuration and then to [Preferred access point] > Select Idea Internet
  3. Restart your phone
Sep 11, 2012 | Nokia X2 Mobile
Configuration setting deleted..pls help me install again to my phone to access web on my nokia N73
you can create new configuration setting
go to setting-> configuration setting ->
personal setting -> create new setting
Nov 27, 2010 | Nokia N73 Cellular Phone
Unable to save gprs settings in nokia 5300 mobile phone, where configuration settings are empty. it shows "only 70 sets allowed settings discarded".\r\nwhen i want to create personal configuration it shows...
Unable to save gprs settings in nokia 5300 mobile phone, where configuration settings are empty. it shows "only 70 sets allowed settings discarded".\r\nwhen i want to create personal configuration it shows "can not add new account, memory full". please help me immediately.........
Sep 22, 2010 | Orange PCMICROSTORE Brand Nokia 5300...
I want airtel mms manual settings for sony ericsson naite j105ico.in
AIRTEL GPRS SETTINGS........ go 2 personal configuration settings, now select a web. AccountName:- AIRTELLIVE Homepage:- http://live.airtelworld.com Username:- BLANK Password:- BLANK UserPrefferedAccessPointSettings : NO ACCESS POINT SETTINGS Proxy:- ENABLE Proxyaddress:- 100.1.200.99 Proxyport:- 8080 Databearer:- PACKETDATA BEARER SETTINGS..... PacketDataAccessPoint :- NORMAL UserName:- BLANK Password:- BLANK go back and select AIRTELLIVE. AIRTEL MMS SETTINGS............ Steps and setting is same as above,but some steps r different which r as following.. In personal configuration settings add new MULTIMEDIA... AccountName :- AIRTELMMS ServerAddress :- http://100.1.201.171:10021/mmsc ProxyAddress:- 100.1.201.172 ProxyPort:- 8799... *** back and activate it...then go 2 MESSAGES AND THEN SELECT MULTIMEDIA MSG SETTINGS...now select configuration settings..under configuration SELECT "AIRTELMMS"
Aug 02, 2010 | Cell Phones
Don't know how to set up the browser...thanks
If you are rtying to connect to the internet using your phone
You should configure first the setting of the network, and it can only be done by requesting to your network provider to send to you a configuration setting, after you recieved it, you'll need to save that setting and it will automatically configure the set up.
call the network service hotline and request for a configuration setting
Nov 01, 2009 | Motorola Mobility RAZR V3
BIOS voltage settings for ASUS M2N-SLI Deluxe 570 SLI chip set.
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
Oct 21, 2009 | ASUS M2N-SLI Deluxe Motherboard
My system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
