Question about LG Studioworks 440SI 14" CRT Monitor
Dear , My LG 440Si monitor is not powering on. I have tried the same power cable for different monitors. All are working. Can you kindly suggest me What the solution to be taken.
  • 51 Answers
SOURCE: Blinking green light with no display
Have you tried connecting this monitor to another computer?
Have you tried resetting the BIOS? That should reset any problem the video driver for the monitor maybe facing.
Posted on Oct 17, 2007
  • 16 Answers
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Posted on Feb 06, 2008
SOURCE: Benq FP71G LCD Monitor - Can't keep POWER ON / Button Problem?
I had the same problem and found that Q808, Q809 and Q805 had failed and which if left long enough can also cause PF801 to fail. I also replaced all of the electrolytic capacitors during the rebuild as it was only a few dollars to do so.
Although in my case Q815, Q816 and Q812 were fine I suspect that they may also fail in time.
Here are the parts which should be available at most electronic stores or online.
Q808 & Q809 - 2SC5707
Q805 - IRFU9024N
PF801 - 3 AMP PICO FUSE
Posted on Jan 22, 2009
safenude
  • 124 Answers
SOURCE: Monitor goes blank , power light goes off.
Click start, then then control panel and click on the power management icon. When you see the screen, look at the power management "scheme" and pick the appropriate setting. I assume that what you are experiencing is what's known as "Power management" . In order to achieve an "Energy Star" rating, the computer must shut off various components to conserve power. If you don't want to have your monitor shut down, select never from the options in the Power Management screen. Thanks for using Fixya.com
Posted on Jan 27, 2009
SOURCE: monitor LG FLATRON E700SH
do any one have the moniter sittungs of LG E700SH
Posted on Jan 28, 2009
Cant find driver for lg flatron 295lm monitor it keeps disconecting from my computer
Hello
OK, a monitor usually does not need any drivers to be installed. Hence, if the screen keeps disconnecting you might want to have a look at the connecting point between the monitor and your computer and the power connection.
Try different VGA cables and power cables, let me know if the problem persists, so we can try something else.
Kind regards
Andrea
Sep 03, 2010 | Microsoft Windows Vista Ultimate Edition
Monitor is not showing the display after booting.
Hello!
Yes you have change the settings of your display to a higher resolution and your monitor is not compatible with that setting, to fix this you can bring your system unit to a friend or neighbor who has a computer and try changing it if your friends monitor is capable or compatible with your display settings. Or if you have other monitor you can swap it.
Hope I was able to help.
Jul 30, 2010 | LG Studioworks 440SI 14" CRT Monitor
LG 440SI CRT
What is the problem with your monitor? i would appreciate if you can give detail information on the problem, so that i can advice on it.
Take care.
Jul 18, 2010 | LG Studioworks 440SI 14" CRT Monitor
My computer cant turn on and its making noises
Did you your CPU Fan inside, that's the one who make some noises inside.
If your computer is failing to start then check CPU inside, all the peripherals double check on it. From VGA Card, Memory and other devices, maybe its not properly connected inside. Good luck!
Jul 29, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Have a lg l1510s monitor and the power green ligt
Have you tried to substitute a different cable? Many times a cable can go bad, and you cannot tell, because of how they are made. Get a different cable to try as a replacement, and see if that doesn't resolve this issue.
-a.
Jul 02, 2009 | LG Flatron L1510S 15" LCD Monitor
Power supply get dropped
what power supply do you mean Sir/Ma'am.
is it the AVR (automatic voltar regulator)?
if its the AVR, just switch it on and check the output voltage with a multimeter (AC range 250)
you should see the voltage output nearly equal to your SERVICE AC voltage
Nov 06, 2008 | LG Studioworks 440SI 14" CRT Monitor
Monitor problem
Your request for the exact problem will require a signal injector and use of an oscilloscope or even more test equipment. One possible cause is the contrast set to minimum.
Sep 16, 2006 | LG Studioworks 440SI 14" CRT Monitor
LG Studioworks 440SI 14" CRT Monitor Logo
22 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
