Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Full of water... no clothes in it... it will not drain.. it will not spin... it flashes "LD" sometimes...when closed and lid lock is on it will say add garmets. yet it is lid locked so you must pause the cylcle to do anything but it wont do anything even when resume is pushed.. tryed unpluging it nothing is happening
  • 44 Answers
Best off to call a certified Service Center such as Sears.
Posted on Oct 16, 2010
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
Washer will not operate error code LD We have unplugged washer moved clothes around and tried to just spin water out. All lights come on and sometimes the lid will lock and sometimes it want but washer...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
  • Lid partially or completely open
  • Lid or other object has hit the timer knob and turned the washer off
  • Lid not locked (by the way, not on all washers) and may be not draining.
    Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
    Make sure the Timer knob is pulled out.
    The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
    If the washer has not drained, it will not go into spin.
    Hope this works.....
    May 01, 2010 | Roper RTW4300SQ Top Load Washer
    Water is draining but doesn't drain the lower basin. shows ob, sl, or ld on readout. Have to unhook drain hose - let it drain then it will usually start working properly.. when the basin is full and it...
    Hi There
    I'm giving you the coeds that you need. So i hope this helps you and let me know how it goes.
    Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
    Press STOP/CANCEL to clear the display.
    ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance
    The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
    Press STOP/CANCEL to clear the display. S Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
    This code will also appear if the user presses the START key while the lid is open.
    Open the lid or press STOP/CANCEL to clear the display.Thank you for writing to fix ya.
    Best Regards Richard
    Dec 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    I am getting an error of LD.. and my lid will not lock and my washer will not spin or drain. was working fine.. until this happened.. I have turned it off.. and then back on.. and tried to get it to spin.....
    It isn't whether the water drained out, it is how quickly the water drained out. Common causes of the LD or long drain fault code are a kinked drain hose or some article of clothing being caught in the pump suction hose and increasing the time that it takes for the water to drain. It has to do with the cycle timer. I would look for some sort of obstruction. Also check the pump impeller for broken/missing blades and that it spins freely. If not, the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helped and best wishes.
    Sep 01, 2009 | Washing Machines
    Clothes washer won't drain - digital display shows LD
    looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
    Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite flashing codes.
    ob means out of balance and ld means lid not closed. so i would guess that you have a washer that is not draining or just needs the clothes moved around.
    if you have a plugged pump it will do the same thing. make sure the pump will drain properly and then try it again. if it still goes out then try it with no clothes. that way you know its not hte clothes causing the problem.
    recheck the pump and hoses. be sure it will drain the full tub or it wont work right.
    Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Whirlpool Cabrio WTW6600SW1: Won't drain
    The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
    Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Kenmore 22082
    OL on my washing machine
    May 17, 2008 | Kenmore 22062 Top Load Washer
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    137 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
