Question about Shuttle Computers & Internet
Problem with shuttle optical drive
When I insert DVD+R discs into my drive, my computer recognizes it as a CD, and wont allow me to write the full 4.7 gigs on it. If I go into a program like nero and use the system info utility, it shows it as a DVD, but can't tell how much space is on it.
My drive is a shuttle optical drive, CR40.
Thanks!
  • 1,183 Answers
Please use the following link to download a small file on the customer's system and on double clicking, this file will automatically remove the Upper & Lower Filters from the windows registery. (Saves a lot of time!!).
http://support.microsoft.com/default.aspx?scid=kb%3Ben-us%3B314060
http://tinyurl.com/ecsy
Scroll down a bit and you will find a download link that says; "Download guided help", just click on it and save the file on the desktop and double click to run the utility. It's fast easy and safe.
Thanks
mandeep
Do let me know if the above solution was helpful,by rating the same.
Posted on Jun 03, 2008
It will not play Verbatim DVD-R disc that I burnt on my computer.
If it can read any other disk, you should burn your disk again because burning process was incorrect. your computer can't recognize the disk. In this case, probably you can't do anything, no way to try to read a bad disk if computer can't even "see" it.
By the way, you should test to read the disk on some other computer.
If happens with ALL your disks, your optical player is defective.
Again test reading with other computer if record was made correctly
As for your device, you should check if worth to repair and decide if repair or replace it.
How to Replace DVD CD Drive in Computer Tower
How To Install Computer CD DVD or Bluray ROM Drive Ep 7
Replace Laptop DVD CD Optical Drive Complete Tutorial
How To Replace the Optical Drive HP Pavilion DV6 Laptop HD
Sep 03, 2015 | Televison & Video
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
How do I enable the drives on my Gateway 505GR?
Enter BIOS SETUP.
Change the "boot order" to put the CD/DVD drive as the _first_ boot-device.
Save/Exit, insert the CD-ROM containing the Operating System, and your computer should boot from the files on the CD-ROM.
Apr 08, 2010 | Gateway 505GR PC Desktop
Cd Drive in Mac iBook 4 is malfunctioning. Disc will not mount.
Shut the machine down. Find the original CD or a retail OS X installation DVD. Start the machine up and immediately hold down the option key. You will see a icon of your hard drive. Now insert the CD or DVD. If it immediately spits out, your optical drive needs replacement. If it does not, click on the U-shaped arrow button to rescan the drives. If the CD/DVD does not show up, your optical drive needs replacement. If it does, choose it and boot from it. If this actually works, you may have a software problem -- this is low probability, but possible.
Keep in mind that the CD and DVD read heads are separate. If one of those is malfunctioning, your drive will accept CDs but not DVDs, or vice versa. If you see this behavior, your optical drive needs replacement.
Oct 06, 2009 | Apple Computers & Internet
Model #GWA-4164B DVD Writer does not recognize any disc Cd or DVD. computer sees the drive when you install a DVD it tries to read and fails . Try to explore it indicates please insert a disc. Firmware is...
It sounds as if the disc drive laser has died, when they burn out they will not recognize any disc inserted. fortunatly a replacement drive is relativly inexpensive to replace.
Aug 24, 2009 | Hitachi Computers & Internet
No disc error video and audio cd works only dvd gets nodisc error
Did you try to test it and play another using another disc?
You may try to clean the optical lens of the unit using a optical disc cleaner available on any electronic shop, it seems that the drive lens is dirty and can't recognize the disc inserted.
Hope this helps.
micro
Jul 19, 2009 | Philips DVP3020 DVD Player
HP Pavillion a712n Desktop PC-CD writable drive space all used up; and it wont recognize blank CD
have not fixed it. Can you fix the title ? I sokld the pontiac. This is about an HP PC. thanks
May 28, 2009 | 1989 Pontiac Grand Prix
Cd drive not working
i have personally faced this issue before, sometimes it does happen that CD/DVD ROM's go bonkers in reading discs, mostly bcoz either the CD/DVD is damaged (scratched etc.) or the lens has gotten dirty.if it is a lens issue use a lens cleaner (lots r avail. in the mrkt) and try again if not im afraid ur CD/DVD is concked
Mar 23, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Set-up not working on sony dvd
After reformatting a computer, inserting an optical disc into a drive will not allow it to autoplay (there is no operating system to take control of the situation). If the disc is bootable and the BIOS is configured to allow booting from an optical drive, restarting the machine with the disc in it should allow the system to boot off of that disc. If this is the problem you are trying to describe, press whatever key (F2, F12, Del, etc) allows you to enter your BIOS setup program and ensure that your computer will attempt to boot from your CD/DVD drive, save your changes, and allow the computer to reboot. This should solve the issue.
Jan 17, 2009 | Sony DRU-820A DVD RW Dual Layer Burner
Transfering my video tapes to DVD
A couple of quick observations: -If you have two or more optical drives you could be inserting the disk in the wrong one. -You may have just misspoke when you said *insert into the DVD/CD burner drive a CD-R disc* but just to make sure you need to be inserting a blank DVD disk and not a blank CD. No offence intended, especially since I?ve made both of these mistakes in the past myself :)
Jan 02, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Computers & Internet Logo
53 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
