Question about Engel Freezer Compact Portable Freezer / Refrigerator- 34 Qt.
How to wire fans to fridge ie computer fans to aid efficiency
  • 4,793 Answers
Easiest way is to buy a desk fan the size you want and make up a box to fit on the side.then wire it up in series with the unit.you decide which way to fit the fan for airflow........
Posted on Oct 16, 2010
Glacier in back of fridge wall, caused by heater going bad, is this a lemon?
If the common in your house is grounded, as it should be in the older wiring systems it should work unless the refridgerator is only grounded through the ground lug. If that is the case AND you know the house is wired correctly throughout, ie no wires switched in any switch or outlet, you can ground the common at the fridge. BEWARE! If one outlet or switch is wired backwards and you do this you will get zapped when you touch the refridgerator.
Jun 17, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Subzero 550 freezer making loud noise if top wire shelf closed
When you shut your top wire shelf you do a few things. First of all you activate your fan. Your fan sits in back of a large evaporator coil which is prone to defrost issues. I would imagine your fan is hitting ice due to a defrost issue. You may want to check your defrost system out. Ie your defrost timer.
or alternatively your fan could be getting old and needs replacing, it could just be making noise.
Joe B, Certified refrig.
Apr 04, 2013 | Freezers
MY HOTPOINT FFA52 FRIDGE FREEZER HAS MADE A LOUD BUZZING NOISE A COUPLE OF TIMES BUT IT APPEARS TO BE WORKING OK. AT FIRST I THOUGHT THE BUZZING WAS COMING FROM THE TOP NEAR THE THERMOSTAT UNIT BUT I,M NOT...
If you can pull the unit out from the wall, find the motor compartment. There, you'll find a black can with the motor and compressor inside it. This usually creates vibration when running. Check the compressor's mounts, to see if they need tightening or have rubber grommets that have rotted away. The sound could also be coming from a fan somewhere in the machine. There might be a fan in the motor compartment. Find the vents inside the unit that blow cold air. Check the guards to see if a foreign object could have made its way into the vents and jammed a fan. Make sure you unplug the fridge before you stick any hands or tools someplace they wouldn't normally go. You may want to let the unit run while peeking in with a flashlight to locate the source of the vibration, but beware of moving parts and a shock hazard.
Apr 03, 2010 | Freezers
Each time i open the fridge door and the the fridge mtr is runing, the buzzer sounds on and off and lights flash
The circulator fan shuts off when the door is open to help prevent the evaporator coil from frosting up and reducing efficiency from the inrush of warm humid air. This is normal on some models.
Mar 18, 2010 | Freezers
Have a subzero set - fridge and freezer. The
First, check the compressor fan. Make sure it is turning. If this fan is not working properly, the refrigerant will be be cooled adequately. This lowers the efficiency of the refrigerator and causes it to run more.
The fan is probably located in the back of the bottom of the refrigerator. It pulls air across the coils and blows the heat out the back of the unit.
If the fan is not turning, the fan motor will need to be replaced.
Oct 14, 2009 | Freezers
I have a 20 ft. Frigidaire upright freezer ab out 10 years old. Model #FFU2QF9FW1 and it will not stay cool enough so that items are about half thawed out. It takes it 3 days to freeze l/2 pint of water. I...
Sounds like it is not working properly to me. If not done already, clean out the radiator and air vents around the compressor to aid cooling.
All freezers and fridges are designed to work in a hot climate so ask if it needs the gas pressure increasing.
If it is gong to cost a lot, now may be the time to get a new more efficient one, it will save you money in the end.
Aug 09, 2017 | Frigidaire 20 cu. ft. / 566 liter Upright...
Hotpoint Mistral frost free fridge freezer.
This is a little hard for me to understand being a yank and all. 0C is 32 Fahrenheit, right so 4/5 is about 40? make sure everything is working, compressor , evaporator fan motor (the one inside) condenser fan motor (the one outside) if you have one. You should have an adjustment for freezer and one for the fridge sections, right. The fridge section controls what amount of cold air comes from the freezer compartment. Check the vents inside, make sure they are not blocked and they open and close when you adjust the control. If this all checks good then check the thermostat. If the compressor shuts off prematurely, then a new thermostat may be in order. If you think you can do this, find the thermostat, by-pass the wires. this will make the compressor run continuously. After 20 minutes or so it should make the desired temperature or close to it. None of the fans or compressor should turn off while this is by-passed.
Dec 31, 2007 | Freezers
Engel Freezer Compact Portable Freezer / Refrigerator- 34 Qt. Logo
147 people viewed this question
Top Engel Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
John Tripp
John Tripp
Are you an Engel Freezer Expert? Answer questions, earn points and help others
