Question about Maytag Bravos MTW6600T Top Load Washer
The barrel came detatched from the top and won't drain the water
  • 44 Answers
Best off to call a certified Service Center such as Sears.
Posted on Oct 16, 2010
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
When the dial is set for a medium load, the water fills to about the mid point up the side of the wsher barrel and stops. Then the inner barrel starts to spin at a moderate speed and the water is thrown...
Sounds to me like the pump is not operating up to par. Open the machine and check all the drain lines form the tub to the pump, from the pump to the waste pipe and also, when you check the tub to pump line, feel up into the tub to make sure you don't have a article of clothing stuck in there. Check the inside of the pump too. Here is a link to a video to show you how to access the pump and lines.
Dec 28, 2010 | Maytag PAV2300 Top Load Washer
How do I drain the barrel
If this is a top loading washer, an easy method of draining the wash tub is to pull the drain hose from the standpipe at the wall and lower it into a bucket. Gravity will allow the water to drain. If the washer is in a laundry room or utility room with a drain in the floor, you can simply lay the drain hose on the floor and allow it to run into the drain.
A less messy method is to use a wet/dry shop vac and pull a vacuum on the drain line to pull the water from the wash tub. Most of the these top loaders have a capacity of about 30 gallons, so you will need to empty the shop vac a few times to empty the tub. Make sure you place the drain hose back into the standpipe when you need to empty the vacuum or gravity will force the water on to your floor.
If you have any questions, please let me know. I hope you find this information helpful.
May 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 111 stuck mid cycle with water in barrel
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Jul 13, 2009 | Washing Machines
Washer won't drain. I washed a comforter and some of the ''stuffing'' came out and now seems to have clogged the washer because it won't drain anymore. I have cleaned out the hose, seems like some of the...
depends on what type of washer it is but it should have a filter on the front bottom of it ,some times they have a plastic cover over them just remove the cover at the bottom of the washer and then turn the filter and pull it out and clean.
hope this helps you
Jul 07, 2009 | GE WVSR1060A Top Load Washer
Barrell doesnt spin
Check the drain hose if to low to ground if so raise hose up to even with the tub top or two thirds up on machine. Some washers don't spin until water is drain out first then the pressure switch turns the timer to spin. Hope this may help.
Jun 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load barrell will not spin on rinsr nor spin cycle
if it is syphoning......pull the drain house out of the stand pipe it is in tooooooo far. once it is too far down it does not have an air gap anymore which causes it to fill and drain and never reach maximum water level. the hose should only be in the stand pipe 6 inches. when you pull the hose out of the wall and you hear it go glub glub glub and water exits the hose that is a major sign of syphoning. And yes it can be intermitten. Let me know how it goes and if you have any other questions.
Jun 02, 2009 | Whirlpool Washing Machines
Some water drains out onto the floor.
the drum seals will need to be replaced. there are seals that are used for the screws that connect the drum to the drive. they are leaking.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Estate TAWS900JQ2 will not agitate or spin or drain
Most likely it is your top door safety switch, this switch is enguaged by a small plastic rod on the bottom of the top load door which goes thru a small hole on the top of the barrel shield, which inturn depresses a switch. Make sure that the switch is working propperly.
Dec 16, 2007 | Estate TAWS800JQ Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
