Question about Canon DW 100 DVD-RW Burner
Quite a few times when a number of scenes are copied in the playlist and the play list is to be recorded on a DVD through DW-100, on completing the connection the message on the Camcorder screen comes "Operation Cancelled" and the system hangs.
  • Canon Master
  • 3,083 Answers
This could be happening for a number of reasons, and one of them could be a slightly compromised laser lens. It could need to be cleaned, or, if it's been through heavy usage, it might need a slight adjustment. Otherwise, there could be some software/hardware random conflicts, which you pretty much have to live with.
There are a number of issues that can occur with dvd recorders, and media is a critical issues, and all dvd/w or r/w media is not compatible with all players. If you've changed the brand of you media, that might be an issue.
Good luck, and hope this helps.
Posted on Oct 16, 2010
Canon DVD burner DW-100 and HG10 burn issue
You can not have any MXP Files in your play list or in memory. The DW-100 Can not burn these files. Once you delete/remove the MXP Scenes from the the Camera the Burner will work fine.
Dec 13, 2009 | Canon DW 100 DVD-RW Burner
Our Canon video camera will record in both HD and SD. We've recorded all of our video in SD so far and I burned some of it onto the Canon DW 100 burner and I can't get it to play on my DVD player. please...
You should burn your videos to a video format that should be compatible with your DVD player to get play. Some video formats will not be able to play to a certain DVD if the DVD player does not support it. You should burn your videos to VCD format to avoid problem because almost DVD nowadays have backward compatibility for all VCD movies. Hope this could help you..Please don't forget to rate me..:-) Thanks..
Nov 04, 2009 | Canon DW 100 DVD-RW Burner
What are the differences in the record modes? (HQ, SP, & LP)
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
  • HQ (High Quality): Recordable time is up to 20 minutes.
  • SP (Standard Play): Recordable time is up to 30 minutes.
  • LP (Long Play): Recordable time is up to 60 minutes.
  • NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
    Jul 08, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
    Did not burn dvd
    The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
    The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
    1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
    2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
    I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
    Hope this helps. Good luck.
    Mar 19, 2009 | Canon DW 100 DVD-RW Burner
    I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
    The DW-100 records discs based on the format they were originally recorded.
    If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
    If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
    My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
    Jan 06, 2009 | Canon DW 100 DVD-RW Burner
    Canon DW-100
    Thanks, I think it works that way. gl
    Dec 08, 2008 | Canon DW 100 DVD-RW Burner
    Too many files to handle
    On the camcorder there is a function that allows you to create a play-list. This play-list group your recording into one file allowing for continuous playback (BUT... the original files cannot be deleted or the playlist will be deleted as well) burn a dvd from the playlist. Automatic grouping doesn't happen automatically on 20003-2008 JVC model camcorders. You would have to do this after you have finished you recordings. Another option is while using the software that comes with the camcorder this allows you to import what files you what to save and group it that way by the date. There is no need to edit if you don't want to.
    Nov 21, 2008 | JVC Everio GZ-MG30 Camcorder
    Sony DW-Q30A Problem
    the dvd writer needs to be replaced,the laser is faulty or miisaligned, the cost of a repair is no longer viable because a new one would cost about $60 (£32.00)
    May 30, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
    Songs in playlist do not play
    It's a bug.  I hit this as well.  You've gotta update the firmware, and you will stll have to delete all your songs and start from scratch before it will work normal again.
    Nov 27, 2006 | Sirius Satellite Radio S50-TK1 Satellite...
    Open Questions:
    Canon DW 100 DVD-RW Burner Logo
    47 people viewed this question
    Top Canon Computers & Internet Experts
    Aashish Chaudhary
    Aashish Chaudhary
    Computer Links
    old marine
    old marine
    Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
