Question about Panasonic SD-YD250 Bread Maker
I have a panasonic sd 257 breadmaker and am having problems extracting the blade out of every loaf I make. It is making large holes in the loaves each time.
    Genius:
  • Panasonic Master
  • 1,280 Answers
That is a problem with all breadmakers. The only way to prevent this is to remove the dough ball from the machine after the final punch down and just before the final bake. I've never done that but it might be a solution, but I have heard others talk about it. If you choose to leave the paddle in as I do then use a toothpick and poke around the outline of the paddle with it. You will still have a hole but it won't be as large. I sometimes use a popsicle stick too. Whatever you don't use anything metal to get it out if you have a metal paddle because you will scratch the non-stick surface on it.
Posted on Oct 16, 2010
  • rorford Mar 07, 2011
    Use a corkscrew inserted and twisted gently into the hole in the bottom of the paddle after you have taken the loaf out of the machine. Pull straight out. Use oven mitt to disconnect the corkscrew from the blade. This works for me every time the blade is stuck in the loaf.
Recipe books
I have several recipe books for bread machines. You can use just about any book from other models as long as you follow recipes for your size machine. I.E. 1.0 pound loaves, 1.5 pound loaves, 2.0 loaves. Just be sure you choose the right loaf size when you program your machine and that your machine has the capacity to make the size loaf you want.
Jan 27, 2014 | Kenmore KTR2300 Bread Maker
How many pounds is xl bread
an xl loaf would be determined by the amount of flour you use. a standard 2lb large loaf is made usingc 560gms (19.7ozs)flour. i make my loaves using 850gms (30ozs) flour. the end result is an xxl loaf. (i don't bake it in the bread pan. i have an extra large loaf tin. one thing to note, is when using more flour all the other ingrediants apart from the yeast need to be increased too . good luck.
jackie
Feb 16, 2013 | Panasonic SD-2501WXC Automatic Breadmaker...
Can you make a 1 pound or a 1 1/2 pound loaf of bread in the Toastmaster 1185 which is a 2 pound loaf machine?
You can make 1.5 lb. loaves for sure. If your pan is the vertical type with one paddle then you can also make the smaller 1 pound loaves.
Aug 27, 2011 | Toastmaster Kitchen Appliances - Others
My panasonic SD 255 breadmaker, after quite a lot of use, is now baking bread with a harder crust than it did in its youth. We can get a softer crust by using the Sandwich loaf setting but then we can...
You never said if you remembered to select the LIGHT Crust setting each time. Did you? Are you? If you ARE using the LIGHT Crust setting and finished loaves are still too dark, I would have to say it's time for a replacement breadmaker. Nothing lasts forever my friend. Besides, it sounds like you got your money's worth anyway, right?
I've owned over 200 breadmaker myself so you can bet that what I'm saying is true. Sorry for the bad news friend.
Hope this helps!
Jun 15, 2011 | Panasonic SD-YD250 Bread Maker
What capacity is it, my 310...llb, 1and one halflb, or 2lb?
I sscrambled all over the blessed internet just to get an accurate description of the CBN310 magic chef for the purpose of determining it LOAF capability...ie...1 loaf, 1 and 1half loaf or/and 2 loaves! I couldn't get this information without PAYING for it, so I decided to ply a safe hand.....I'll only make 1&1half loaf at a time.....thanks so much TMO
Apr 10, 2009 | Magic Chef CBM310 Bread Maker
Big chunk out of loaf bottom
Unfortunately that will happen almost every time. I have the instruction booklet and it states it may even BAKE into the bread as well. No way of getting around the HOLE in the bottom of the bread.
Feb 11, 2009 | Breadman TR875 Bread Maker
Bread does not rise
  • Make sure it is good quality Strong White Flour (not plain flour)
  • The amount of water you use is very important. Use scales for accurate results - 1ML = 1G for water
  • Make sure the yeast is as per instructions regards type/quantity/quality.
  • Double check that you are running the correct program.
  • Always put the yeast in first, as you dont want the water in contact with water
Having failed that I would return the machine
Jan 13, 2009 | Panasonic SD-YD250 Bread Maker
Top of loaf sinks in
I am having the same problem, I have made 3 loaves of white, they all did not turn out, and I played with the recipe a bit to solve it, but I keep getting the same result!
Dec 16, 2008 | Oster 5838 ExpressBake Bread Maker
I have a problem with uneven shaped loaves
The paddles fit two ways, so what you must do is have them facing opposite ways, then they fight with each other and elongate the loaf
Dec 30, 2006 | Black & Decker B2000 Bread Maker
Panasonic SD-YD250 Bread Maker Logo
882 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
