Question about Refrigerators
Refrigerator won't get colder than 45 degrees/ Freezer side is working fine
The unit is a Whirlpool, model ED27DO. The unit runs for awhile then turns itself off. It is supposed to do that or should it run until it has got down lower. The refrigerator has been set to the coldest setting for the past 12 hrs. I checked under the unit and the coils and fan are fairly clean. Any ideas??
  • 1 more comment
  • Tri-Soc Jun 03, 2008
    The freezer temp is at 6 degrees Fan is working. No frost on back panel. Setting for frezzer is "B" the middle. I moved the fridge temp setting back and forth and it seems to have helped. The unit is now running constantly and temp is down from 49 to 45 in the last hour. Might of just been a sticky thermostat.
  • Anonymous Apr 16, 2009
    This is exactly my problem in my whirpool refrigerator.I defrosted it checked the coils How do you check the damper door?
  • robert samples May 11, 2010
    look for frost on the back panel of the freezer section and how cold is the freezer the freezer supplies the cooling for both sides and blowes to the refrigerator side via a fan do you hear a fan running in the freezer side and whats the setting on the freezer side
    President:
  • 1,314 Answers
The fridge thermostat is not a true thermostat it controls a damper door the freezer thermostat runs the compressor in order for your refrigerators to reach the proper temp the freezer should be about -8 to-10 set your freezer thermostat lower and see if it gets lower .at the mid point setting it should be about -8 not 6 you may have a problem with its thermostat or a leak in your system reply to me tomorrow and tell me if lowering the freezer thermostat help we want it about -8or-10 and the best way to check your refrigerator temp is put a glass of water in it and stick your thermometer in it and if need be you can e mail me at b4829@yahoo.com just referance your promblem
Posted on Jun 03, 2008
The fuel pump stay runnning for awhile before the car starts
Don't really understand your question but the fuel pump is suppose to run when you turn the key on. Runs for a few seconds to build to the proper pressure and then shuts off until the pressure is needed again. In most cars it will cycle every time you turn on the ignition switch.
Mar 02, 2015 | 1997 MERCURY COUGAR 71-1770 TurboWire -...
Freezer temp not steady
it is cycling different because the environment is much colder..
Jan 21, 2014 | Whirlpool Refrigerators
PSH23PSSSB
keep appt...unplug unit remove bottom part of freezer so you can see fan then get a blow dryer and melt all ice from fan. be sure you can turn fan with your hand. after this is done replace bottom plug unit back up and turn control to regular settings
Jun 27, 2012 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
How do you activate the turntable on the whirlpool wmh1163xvo1
Hi and welcome to FixYa, I am Kelly,
The turntable motor is supposed to run anytime the unit is heating. If it is not turning the turn table motor most likely has failed. It is located on the very bottom of the unit.
See this diagram item 7:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5512685&diagram_id=28123343#d28123343
Also check the spline on item 6 of the above link.
The motor has a 2 wire connection and 2 mounting screws.
I think the motor has most likely failed.
Thanks for choosing FixYa,
Kelly
Aug 16, 2011 | Whirlpool Microwave Ovens
My sub-zero 642 will not get colder in the freezer than about 9 degrees and the fridge won't get colder than about 45 degrees. I turned off the breaker and vacuumed the coils, but still no change. ...
The Sub Zero 642 uses independent refrigeration meaning the freezer and refrigerator each has their own system. Best to have an "Authorized Factory Service Company" check it out.
Jun 08, 2011 | Refrigerators
Product is about 6 years old. Used in basement. Worked great until this year. Now will run continuously but collect little water. What type of service do I need? This is a 65 pint per day Whirlpool.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool 75-Pint Dehumidifier
I have a Goodman Furnace that doesn't turn on. If I spin the blower it will run, blower just buzzes and still buzzes while running. It shuts itself off after twenty minutes. I can resets it and spin the...
First I would suggest that you replace the start capacitor on your blower motor but if it is running for awhile that makes me wonder if the thermal overload is shutting your motor off. You can replace the start capacitor and then if it starts as it's supposed to and then shuts off you'll know the motor needs replaced also. I hope this helps you . THanks
Nov 30, 2010 | Goodman CLQ24AR42 Air Conditioner
Refrigerator will only get 58 degrees no colder, freezer is working fine, dial on fridge is on coldest setting...help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a hotpoint side by side model csx20ba xawh. the freezer will not get colder than 20 degrees and the refrigerator will not get colder than 48 degrees. what do you think the problem is.
make sure everything is clean behind and underneath fridge, also make sure fan is blowing across condesor coils and all covers in back are in place
Oct 21, 2010 | Hotpoint Refrigerators
Refrigerators Logo
1,677 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
