Question about Robert Sorby RS200KT Multi-Tip Shear Scraper
Please could you tell me the Robert Sorby RS200KT screw thread sise and pitch
  • 30 Answers
USE THE SAME HARDENED MACHINE SCREWS AS PROVIDED BY THE MANUFACTURER.
USING MACHINE SCREWS NOT PROVIDED BY THE MFG WILL MOST LIKELY VOID ANY WARANTY.
SOFT METAL MACHINE SCREWS WILL MOST LIKELY BREAK SENDING A CUTTER FLYING THROUGH THE AIR. NOT TO MENTION THE TROUBLE OF EXTRACTING THE SCREW FROM THE RUINED TOOL.
Using a cheap imported thread gage I checked the Mfg's machine screw and brought home a new metric 5mm .80 machine screw that DID NOT FIT.
Hmmmm.............
I spent 20 minutes digging though my huge coffee can of machine screws finally found one that fit the tool.
Time to get out the import thread gage set again.
THE THREAD SIZE "APPEARS" to be a #10 - 32 TPI socket cap, button head machine screw.
I have not tapped a #10-32 hole in steel to test the origional Mfg screw.
I have not gone to the hardware store yet to purchase a #10-32 nut of screw to verify this machine screw size.
IF A CLEAN OILED MACHINE SCREW DOESN'T SCREW IN WITH YOUR FINGERTIPS EASILY DON'T FORCE IT OR USE IT.
YOU WILL MOST LIKELY CROSS THREAD THE TOOL.
Posted on Jan 18, 2011
  • Tinker2011 Jan 18, 2011
    Just went to the hardware store and the brand new #10 -32 TPI machine screw seems to be the correct size.
Schematics manuals
Take the TV to a local NAPA. they will check it for you and get you the appropriate screws. I looked for a manual, and they dont say thread pitch or diameter of screws.
Jul 28, 2014 | Samsung UN28H4000AF 28 720p 60Hz LED HDTV
What is the size of the bleeder screw on a brakeware wheel cylinder part no 33614
Measure the bleeder screw nut &
thread dia & thread pitch
If you can't do that I'll take the 68 of your hands
Jul 17, 2014 | 1968 Ford Mustang 4.7
How do you tell what size thread is on a tie rod for a 2002 gmc envoy?
Measure the outer diameter of the outer tie rod
threads & the thread pitch of the threads
If it appears to be a metric size,the thread pitch will
confirm that & you convert the diameter to metric
by dividing by .0395
Sep 13, 2013 | Cars & Trucks
Calcuation of pitch of the screw and least count?
the pitch of a screw is the distance the thread moves in one complete revolution . OR in the sae measuring system the number of threads (points) in one inch. So if you have a half inch dia bolt and you count the number of threads in one inch along the bolt and you had 20 threads then the pitch would be 20 threads per inch or in metric it is measured as the distance between the points so if the distance between the thread points was 1mm the bolt would be measured as the dia. (say 12 mm) by the distance between the points of 1mm or 12x1.5
Sep 24, 2012 | General Tools Mfg No. 714 Quick Check...
I need a missing screw for my baby crib the name for the screw in the manual factory in screw JBC 06x16mm is a Carter crib.. i hope u hear about ya soon.. thanks
You can get this screw at any hardware store.the dimensions you listed dictate the exact size and thread you need. The first number is the size of the screw (diameter, in this case in millimeters). And the second number is the pitch of the threads on the screw. Pitch is the distance between one thread to the next thread in short (in millimeters in this case). The only other thing you would need is the length. In short any 6mm X 16mm screw will do so long as you have the right length as the screw will come in many lengths.
Regards, Tony
Apr 13, 2011 | Toys
My husband has a Homelite XL-2 chainsaw and the muffler came loose - what kind of a tool do you use to tighten it.
I think this is an older model similar but lighter than the good old CF 55. It may have two screws of #10-32 size thread on the top and bottom of a small narrow muffler that has lots of horizontal slits. It is best to replace these with SHCS socket head cap screws of the exact same length and pitch of thread and try to use some locktite blue thread lock fluid to keep them in there. Beware there are lots of different screw pitches used like 10-24, 10-32, 1/4-28 so you have to have an old one to match up when buying two new ones. Reverse it and see if it goes into the threads of the new screw beside it. These SHCS screws have the best thread and will use an allen key in english size. Larger hardware stores will have all this stuff and even seperate allen keys for that size only. If they are left loose they kill your ears, and can strip and then you can never get them tight again. The material is quite week so be very sparing on the tension after it bottoms out on the muffler, a half turn of tension can sometimes be all you can do in cast aluminum.
Apr 09, 2011 | Homelite Garden
Looking for a lens adaptor to allow 39mm screw lens to fit an M2 camera body
You just need a Leica M to Leica screw adapter. Note that this will be different to the adapter you need if you want to use non-Leica 39mm screw thread lenses as the thread pitch is different.
There are various suppliers but you can find the information you need here and here. The links are for convenience only and not a personal recommendation of any supplier.
Hope this helps, if not then please add a comment and I'll offer further assistance. Otherwise please take a moment to rate my answer.
Mar 21, 2010 | Photography
I have old glass door knobs and the shafts are stripped and also need the set screws. Where can I find this parts?
Probably all you need are the set screws to lock them in place. They are sometimes allen head set screws, though some older ones will have a flat head screw like those shown here. In either case, a good hardware store with many drawers of small specialty screws should be able to set you up with what you need. Take a knob or two with you and make sure to get a screw with the correct size diameter and thread pitch, so you don't strip out the threads in the knob. (You can check the knob using longer screws to determine the correct dimensions, then find a set screw that matches.)
You could also try a specialty catalog along the lines of Van ****'s restorers, click here, or a specialty hardware supplier online like the one here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 08, 2009 | Hardware & Accessories
Replacement screws for connecting the power wires
The smaller screws should have been 5mm dia with a 0.8mm thread pitch. The larger ones are probably 8mm dia. with a 1.25mm thread pitch.
Is 5/16 too large or too small? If 5/16 is too large, the screw is probably 7mm.
Do you have one of the original B+/ground screws? If so, it should be easy to measure it and get the correct size.
Apr 25, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Robert Sorby RS200KT Multi-Tip Shear Scraper Logo
123 people viewed this question
Top Robert Sorby Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Robert Sorby Measuring Tool and Sensor Expert? Answer questions, earn points and help others
