Question about Cisco Linksys WET610N WirelessN Bridge Network Bridges
I have about 20 linksys wet160N bridges on my network - what utility i use to detect them and configure and manage them
Is there a driver for the SMC2870W and Mac OS X?
This is a standard wireless ethernet bridge and does not need a special driver for MAC OS. It is a Plug n Play device and should self configure using TCP/IP . Here is the manual : http://www.manualslib.com/manual/154817/Smc-Networks-Smc2870w.html?page=20#manual. Your Mac should see the wireless signal. You could use Safari browser to configure if needed. Apparently the Configuration utility is for older windows systems up to XP. You may need some networking skills to do the configuration without it. Good luck.
Mar 07, 2015 | Office Equipment & Supplies
How do i switch to windows wireless configuration utility
If you are using Windows XP, Vista, or Server 2003, you have an option in how your wireless network card is managed. You can choose to use your manufacturer's Configuration Utility software, or you can use the configuration software built in to Windows.
If you wish to switch between your manufacturer's Wireless Configuration Utility and the Windows Wireless Zero Configuration service:
1. Go to Network Connections (from the left panel of My Network Places)
2. Right click on the icon for your wireless network card, and choose Properties
3. In the Properties dialog box, choose the middle "Wireless Networks" tab
4. Check or Uncheck the box on the top that enables Windows management of wireless connections
5. Click OK
A reboot is recommended. If you are using any form of WPA or 802.1X security, you will likely need to reboot the computer before you will be able to access your wireless Access Point -- even if it is configured correctly.
Even when both the manufacturer's software and the Wireless Zero Configuration services are running, the Configuration Utility should detect when Windows is not managing the connection and give you access to its own configuration options.
Likewise, Windows should detect when it is not enabled to control the wireless network configuration, and disable access to the Windows configuration options.
Advanced Troubleshooting:
Before proceeding, be sure to download a local copy of the manufacturer's software and driver should you find yourself with a disabled network card and a need to reinstall the software.
A. If you suspect that Windows is interfering with your wireless network, regardless of the setting, you can disable the underlying service. If the Wireless Zero Configuration service is disabled, Windows will not be able to manage the wireless network -- regardless of any setting. To permanently disable the Wireless Zero Configuration service, click Start, Run, and input services.msc and press Enter. In the Services window that follows, find the Wireless Zero Configuration service, double-click it, and change the startup option to Disabled. Reboot. If you still have issues, uninstall and reinstall your manufacturer's software now that the Wireless Zero Configuration Service is disabled. It should set itself up correctly now.
B. If the Manufacturer's configuration software is interfering with Windows' management of your wireless card, consider uninstalling your Manufacturer's software. Windows only needs the driver in order to communicate with your card and manage the wireless network. Everything else is optional. Remove the software from Add/Remove programs. The uninstall program might give you an option to uninstall everything except for the driver, or it might have separate Add/Remove Program entries for the utility. If it does not, then reinstall the software using the local copy you downloaded and look for an option that installs only the driver.
Mar 12, 2013 | Acer Aspire 5536-5224 Notebook
Hello, I have a WRT150n wireless network home router I stop use since a while. I am trying to use it back, but I do not remember the network security key to connect to the Internet. It detect the signal,...
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 03, 2011 | Cisco Computers & Internet
I upgraded to windows 7 and now my linksys (WMB45G) wireless music bridge software utility doesnt seem to work anymore
It seems like a driver incompatibility issue. You may be need to contact linksys and see if they have a modern driver
Nov 27, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Linksys WMB54G: No Connection Via the Software Utility
It appears the configuraion IP address you are using is wrong it should be 192.168.1.100 or 192.168.1.1
Jan 03, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Connect befw11S4 with wmb54g
You dont need to open ports on the router. Just configure the music bridge with the same wireless settings as your router so that it will work.
Jul 24, 2008 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Wmb54g and apples
The utility needs to be installed in a computer in order for you to use the WMB54G and it will only work with windows version. You can't use it on a MAC computer.
Jul 10, 2008 | Linksys WRLS BRIDGE |WMB54G MUSIC R
How to Use as Simple Bridge
set the uptime variable to "0" in the main bios sytem configuration 7
Nov 11, 2006 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Help with my wet11
Can you connect to the built-in Web server or configuration screen?
Aug 07, 2006 | Linksys Instant Wireless Wireless Ethernet...
Cisco Linksys WET610N WirelessN Bridge Network Bridges Logo
303 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
