Question about Apple iPod touch
I had a cracked screen but everything was fine i had no problems what so ever with the itouch i went to take it in and got a brand new screen but when i try to touch the screen it wont respond to me it turns on but it just wont respond to me touching the screen
  • 1,188 Answers
That means you have a bad digitizer. When the screen was changed so was your digitizer which is a part of the touchscreen on the back. When your glass was changed so was the digitizer which is attached to it. You a new touchscreen...
Posted on Oct 16, 2010
I have a Philips 42PFL7422D/37 42-Inch that went out a few weeks ago. After some research i figured it was the power supply board, not it. I knew it had fried some caps somewhere, replaced the master and...
Good day Richard!!!
Actually sir there's no way of figuring out the screen whether it is good or bad unless you try to test it in actual..
You said your unit is working fine now but the screen have cracked right?so you need for that TV from ebay is the screen only?. if that so,it should be the same brand and model for your old one..
If the brand and model is the same..just swap all board such as T-con,main,powers supply and inverter board from the old TV to new from ebay that's it..
The only thing you can visually check if there is a crack..But don't worry LCD screen is not like plasma that burnt gone bad even there is no crack on it..LCD screen is not gone bad unless it broke or have crack inside like yours..
Hope my suggestion will help you..
If you have more queries or clarification just reply to this tread...
Thanks for using fixya..
Feb 28, 2012 | Philips 42PFL7422D 42 in. LCD TV
Will not recharge. screen absolutely blank and no
The problem can be in one of two places:
1: the power source (computer, wall charger, whatever you're using to charge)
2: your iTouch
If you have a second charger, or car charger, or can borrow a friend's charger, try using that first. If you're able to get the green "Charging" battery with an alternate charger, then your iTouch is fine and you just need a new (cheap!) charger for it.
If your iTouch still doesn't charge with a known-good charger, then your best bet is to find the closest Apple Store and take it in for testing there. When my iTouch stopped connecting to WiFi networks, they tested it to verify the problem and handed me a new replacement on the spot.
Good luck, and let me know if this helped!
Oct 24, 2009 | Apple iPod touch
Broken screen on sidekick 3
To replace the cracked screen follow the guide below. It is fairly easy to do and runs about 30 dollars from ebay.
Here is a guide for it
Sidekick 3 LCD Screen Replacement
New Sidekick 3 LCD Screens for Sale
Sep 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Where can I go to fix a cracked itouch screen and how much would it cost to repair?
send it in to apple. Im not sure exactly, but It will be around 120-up. Its not worth it, id just buy a new and improved itouch. My friend bought a mac his screen cracked, they said 1000 to fix the screeen, when he could just buy a new one for 1200!!!! its a rip off so id just go to walmart or bestbuy and get you another one.
Aug 13, 2009 | Apple iPod touch
Dropped itouch now half of screen is gray everything else works fine just can't see half the screen
It's most likely a broken LCD. You can use a ipod repair guide that will show you how to replace the screen step by step, or you can go to the ipod repair nyc.
Jul 20, 2009 | Apple iPod touch
Cannont transfer podcasts to itouch from itunes
It could be a bad file. If you're resetting your device, and then adding you music and such back, there may be some bad song, or app that is corrupting your device. On my Mp3 player, it would get stuck on a song that wasn't really there, so I found some corrupt goofy Weird Al song, removed it, and it never happened again.
Jun 18, 2009 | Apple iPod touch
Itouch applications won't turn on.
I had exactly the same problem, you have to sync them on itunes. Plug in your itouch, open itunes and make sure it is the version with an applications section in the libary. Then click on your itouch in Devices go to the end applications tab and you have to sync them. This worked for me.
Feb 07, 2009 | Apple iPod touch
Music on Itouch shows up in Itunes but Itouch says No content add from Itunes
First you need to restart your itouch.
Then, plug it in to your computer and wait for iTunes to pop up.
Select a few songs from your library or some movies that you have and drag them to your iPod.
What I did was, dragged some movies on my itouch to the tv shows folder as soon as i did this everything popped back on to my screen
Sep 10, 2008 | Apple iPod touch
My son dropped his itouch and the screen has cracked. Brand new, only had it 3 weeks
Just search Google for "ipod touch repair". There are many services available to repair your iPod. I would start with www.apple.com/support/ipodtouch/ but they may be more expensive than the independant options.
Jul 17, 2008 | Apple iPod MA446LL/A MP3 Player
Apple ipod itouch connection to wireless internet
It's since the touch doesn't officially support WPA PSK and only supports WPA2. What will work is WEP and although it is less secure very few people will bother cracking your network. If you continue to have problems with your secured connection try putting the hex key instead of the passphrase (you set hello as your password the hex would something like 0X34Hg65) it is usually displayed just beneath the password you set.
Feb 08, 2008 | Apple iPhone Smartphone
Apple iPod touch Logo
107 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
