Question about Yamaha Mg82cx Stereo Mixer
I purchase Yamaha M82 mixer today connected it my computer with rca cables to computer. I connected mic in 3pin connecter I cannot get sound from microphone please help
  • Michial Gueffroy Oct 23, 2010
    Is your microphone cable in good working order? Does your microphone require phantom power? Are you getting sound from your microphone through the mixing board using headphones plugged into the mixing board? Have you carefully read the manual for the mixing board? Have you had other signal sources with line level plugged into the sound card on your computer?
  • 4234 Answers
SOURCE: how do i connect yamaha mixer to pc or yamaha
I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
Posted on Mar 11, 2010
  • 611 Answers
SOURCE: I am using the Yamaha
Unfortunately, I do not have a solution for you. However, I recommend calling Yamaha, as they should be able to help you troubleshoot the problem.
Posted on Feb 07, 2011
  • 298 Answers
SOURCE: The speaker connected to my
Assuming that you have checked the speaker leads for broken connections and that you know the speakers themselves work okay (test with a different amp) and that you can hear sound on the headphone socket
  1. Check that you actually have the power amp switch in the right position for the outputs (monitor jacks or main neutrik/speakon sockets) that you are using (see page 25 of the manual)
  2. That your speakers are connected to the speaker outlets on the rear panel and not the 'main outputs' on the front panel, which are for use with a separate power amplifier
  3. Check the mute button is not in
  4. You have turned both the master volume controls up.
If none of the above solves the problem it is likely that the overload protection fuses on the amplifier output stage have blown and need replacing - take to a repairer
You can find the user's manual here
http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/emx512sc_en_om_d0.pdf
Posted on Feb 10, 2011
  • 137 Answers
SOURCE: I HAVE THE YAMAHA MG82CX
there is a main output, conect it to the aux in line or to the microphone line.good musics
Posted on Mar 21, 2011
jdvillanueva
  • 2098 Answers
SOURCE: I have a yamaha Emx312sc
Hi lholton,
This symptom indicated that you have a faulty OpAmp IC in the Mix circuit board. The IC's involved is the NJM2068M-D and NJM4558M-D. If I'm not mistaken you have more than 15pcs of this IC's in the circuit board that control the mics inputs. This is a 8-pin IC in D package. You must have at least 2 good IC's spare if you are going to DIY to swap or compare the reading of each IC's in the board.
Also, bad solder joints must be consider in that board and in the power supply feeding this board. Check it first, this is hard to spot, I would advice you to work in the brightest area or used table/portable lamp and magnifying glass. Re-solder as much as possible.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 09, 2011
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
How to use the behringer 802 mixer and connect it to the computer
There are a variety of ways to accomplish this, but the two most common ways are:
  1. Purchase a BEHRINGER USB interface -- like a U-CONTROL UCA222. This will allow you to use the USB port for your sound In/Out. This will also require RCA cables to connect from mixer to UCA222 unit.
  2. Or...purchase a dedicated sound card (preferred) like an M-Audio Audiophile 2496 that can be installed in your computer (not for laptop). You will also need I/O RCA cables to connect.
Dec 26, 2014 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
Jan 30, 2014 | Behringer XENYX 1202 Premium 12-Input...
Can't get cd player to work in my ub802 mixer.what am I doing wrong.I have connected it via RCA cable from cd player to mixer tape in .is this correct.I also have the mixer in tape out and phantom...
Phantom should ONLY be on if using CONDENSER mics or a DI box requiring phantom power... yours should be OFF. cables should be correct. The 2 Trk to mix button should be down.
Jul 04, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Wound the yamaha MG102c be good for a small duo or solo
The mixer is strictly a mixer. You would need to amplify to drive speakers. Used as a mixer it is fineand would support up to 4 mics.
It does have phantom power for use with condenser mics if needed.
Please use balanced lines (TRS) when connecting to the external amp.
Apr 21, 2010 | Yamaha Mg102c Stereo Mixer
How do i connect yamaha mixer to pc or yamaha receiver
Dan
Mar 09, 2010 | Yamaha Mg102c Stereo Mixer
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Connecting dgx 530 with computer
try using stereo cables (RCA)....thats what i used before i went to 1/4 cables after adding a studio mixer.
Dec 09, 2009 | Yamaha Full-Size Keyboard
Yamaha Mg82cx Stereo Mixer Logo
120 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
