Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Have a 124T02-0887 (6.5 hp?) Briggs lawnmover engine, no spark. Removed flywneel to look for points & condenser, but found none. I have an older B&S engine with points & condenser under flywheel and I can manually spin the flywheel to generate spark consistently. Are there points & condensers on these newer type engines? Thx in advance.
2 Suggested Answers
  • 409 Answers
SOURCE: what is the gap between he condenser and the piont
The point gap on all Briggs and Stratton engines is .020 inch
Posted on Mar 17, 2010
Why is there no fire to spark plug on 6 hp brigs & stratton engine
replace your ignition module and or coil,i dought you have points and condenser,so basically that's all that is left
Aug 01, 2014 | Briggs & Stratton Garden
Vanguard 31hp
Many places to check!!!!-----Battery first---On-Off switch next----Take plug out & connect wire back----Try to start & watch plug for spark---If none,try new plug----still no spark,call good mechanic. If engine does not have electronic ignition,next place to check would be is points. Most Cam,points & condenser are harder to find.
Jan 14, 2014 | Briggs & Stratton Tools & Hardware -...
Condenser on 8 hp briggs engine corroded /leaking can this cause no spark
if condenser has leaked provided it is not oil or greese i would say that would cause a defective spark.
May 20, 2012 | Briggs & Stratton Ignition Kit 2-8 HP...
Model H80-155003 engine magneto has no spark. Replaced coil, condenser & points. still no spark. Set points at top dead center of cam to .020. I need to check wiring, I have digital multimeter. I...
Check the ignition cutout which should short the coil to ground to stop engine, isn't operating while you are cranking engine.
To check grounding, measure resistance from chassis to non chassis side of points.
This should be very low (= resistance of coil primary) and reduce further when points close.
Feb 21, 2011 | Briggs & Stratton Ignition Kit 2-8 HP...
What is the gap between he condenser and the piont
Mar 16, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
B&S 3.5hp rotorvator. No Spark
I would first change it over to electronic ignition, you can purchase a kit online.
You did not tell me you changed the spark plug, have you ? Please let me know.
www.smallenginewarehouse.com
Feb 07, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
108 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
