Question about Vizio Televison & Video
I have a vizio VS42L HGDTV the screen has been turning dark on the left side of screen when you turn it on and last for about 45min you can tap the top or side and it will go away but it always comes on dark for the initial power on up to an hour of viewing what can I do to fix it?
  • anella_c Oct 16, 2010
    thank you so much that does make sense we are going to try this solution...would you have a more specific description of what the tubes look like and exactly where they're located...I'm pretty sure my husband can figure it out with a little more description...thank you
  • Vizio Master
  • 11,800 Answers
Your tv has it's lcd screen backlit by some special neon tubes, called CCFL tubes. In your case the connection to one of them is bad so it's getting its power only when the heat from the other tubes and components expands the metal from the pins in the connectors.
To fix it you will have to take the back cover of the tv off , take off the tube shrouds and reset the tube in its connectors - eventually pinch them a little with pliers before reinserting it.
Posted on Oct 16, 2010
  • Azrael SRL Oct 16, 2010
    Have you seen those economic bulb that you should use instead of the regular ones? They are exactly that - CCFL tubes. Just that in your tv they are straight and hidden in the frame of the tv , right on the side of the lcd panel - they are covered in reflective shrouds. You can't miss them.
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
VIZIO M701D-A3R SCREEN GHOSTED WENT DARK OVER HALF
Aberrations of picture on these sets can usually be traced to a problem with the t con board.
May 26, 2016 | Vizio Televison & Video
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
Vizio 46 inch black screen on left side
Sounds like you either have a faulty LCD panel tab, failed LCD driver board, LCD/t-con panel bad connection, or a bad t-con. You will need to get a diagnoses to be sure.
Dec 15, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
I have a 2008, Vizio VO47L 47 in. LCD TV. When I first turn it on, the left side(facing) of the screen is dark. Not completely black just shadowy dark for over an hour. Then it goes away, It used to last...
Faulty T-con board or mainboard (AKA tuner board)...the tapping would make me believe it to be the connection of the LCD panel to the T-con board that is causing the issue! This board is located on the top of the tv while looking down from the back. Replace it and you will be good to go!
Please rate if this helped :)
Mar 08, 2011 | Vizio VO47L 47 in. LCD TV
Vizio vs42l service connection
hehe
okay ding dong, unplugg tv for 60 mins and use an S Video cable based on RCA jacks
jacks to tv and the S video jack to lappy
Jun 19, 2009 | Vizio VS42LF 42 in. LCD HDTV
Televison & Video Logo
117 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
