Question about Epson STYLUS CX3900 All-In-One InkJet Printer
Error light wont go out, and button wont work for sizes etc.
    Problem Solver:
  • 10 Answers
Check the computer for the error code, most commonly a empty/faulty ink cartridge or a service error
to resolve either replace offending ink cartridge or note error message and take in for service,
Posted on Jun 03, 2008
Dell inspiron mini wont start when pressing the start button the optical mouse light up laptop wont start I tried the static charge but nothing happens pls help,
If the computer is under warranty you should take it to Dell. If not you can try removing the battery and try to turn it on. If that does not work then you might have to open it up and remove hard drive and memories to see if that helps turning on. My best advice is take it to a service center.
Oct 04, 2014 | Dell Inspiron Computers & Internet
Why wont dell i15rv-9762blk wont turn on
Obviously there are no error messages, so it isn't a simple failure.
Several reasons:
1. Dead or damaged battery - look for laptop battery error light or replace battery (borrow a working battery to test)
2. Dead or damaged Power Supply- look for power-on light to confirm operation. Replace PS if dead. (Borrow?)
3. System board failure. No lights/errors messages etc. Place warranty claim.
Aug 10, 2014 | Dell Computers & Internet
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
My xbox360 powers up with a green light from the middle and thats it , it don't work or connect to the controllars (not wirelessly or by the usb port) . and the four circling light don't work .please help
switch the xbox off and if you have any hard drive etc connected to the xbox or usb devices disconnect them , then switch it back on while holding the sync button, the one you press to pair the controllers with , hold that for 30 seconds and then release it, see if it will show up on the tv. If it still wont show anything on the screen , check all cables, borrow one that you know is working to try on it. if that doesnt work try another power supply. The best way to test it though is to take it to a friends and unplug there xbox and use their leads and power supply to see if yours boots up. Another check you can do is hold the sync button in and press the eject button , if an error is happening the ring of lights will change , you need to press eject 4 times, without letting go of the sync button, each time you press it the red lights will come on, code is as follows
Four lights =0
three lights = 3
two lights = 2
one light = 1
so if you get 433
then your secondary error code is 033
reply with what your error code is here
Apr 16, 2011 | Microsoft Xbox 360 Console
Drum error light is on
For the error you described however you would need to check and clean the contacts for the drum on the left side of the inside of the machine.
if it's a drum life error then you either need to replace it and/or reset the counter.
to reset the drum counter, open the front cover, hold down the start button until all lights come on, then release the button and shut the front cover.
Pull the drum cartridge apart to clean the charge assembly properly, it's very easy to pull apart. just make sure you don't break the corona wire in the process.
The printer has a light sensor on the drum/cartridge in the middle of the right hand side (assuming your facing the printer) - its a little circle /window that it uses to check for light. If you cover that with something that doesn't let light in (A small piec of cardboard etc) then you wont get that error anymore and you'll print happily ever.
Feb 23, 2011 | Brother HL 2140 Laser Printer
I have a fisher & paykel aqua smart WL26CW1. I just replaced the module. I am now getting an error code of 9. What does that mean?
Hi dear.That's related to size error.When you replace the motor control module you need to set the machine wash capacity like:5Kg or 7.5Kg.To do that please follow the steps: Phase 1 to 6 Size Switch Error
The Display size switch setting does not match that stored in the memory.IW machines, Phase 5 and 6
To access Size Setting Mode. Push and hold the Fabric care button and then press the Power button to enter Size Setting mode. Select the correct size on the display by pushing the White button next to the correct size (phase 5) or using the Adjust button to highlight the right size (phase 6). Size setting is then achieved by pressing the Power button. Powering off will set the size into the memory. Check the size is set before starting a cycle.
I hope that helps.Thanks.
Sep 03, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
When I try to print the triangle with an exclamation point flashes and doesn't print
This is the 'Attention' light. It indicates that the cartridge door is open, or that other errors exist.
Not great info, but you need to methodically eliminate the possible causes of the error....
1. Try putting some paper into the Manual feed tray / slot. It may be waiting for you to feed paper manually. Check your printer driver settings....
2. Press the 'Go' button. It will make it print from Tray2
3. Check your Printer driver settings, and 'Page set up' in the application
4. Switch the device off, and unplug the data cable.
5.Switch it back on.
6. Print a configuration page from the printer control panel by pressing the Go button (the green one) until the green Ready and Error light start blinking.
7. If it prints these pages successfully, then the problem may be elsewhere (PC software, application, corrupt data, etc) but check the settings on the Configuration page as well.
Make sure they match your system, paper size and type, feeding options etc....
Dec 21, 2009 | HP LaserJet P2015dn Printer
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Datamax M-4206 - error light whenever load or print labels
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked. Also verified that the sensor type (gap or black mark) in the software is correct.
Sep 09, 2008 | Datamax M-Class M-4206 Thermal Label...
I can only receive one page each time
Make sure that the paper size set on the machine matches the paper that you have in the cassette. Also make sure that the sender is not sending legal-size documents if you are using standard size paper.
Is the machine giving any type of error message or code when the error light comes on?
May 15, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
411 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
