Question about Canon PowerShot A720 IS Digital Camera
The catches on the part that hold the batteries has worn off and the battery door will not stay closed. Can the part that holds the batteries be replaced? If so, where can I get a part?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
If you're willing to do the replacement yourself, you can order the parts from
http://uscamera.com/a720is.htm
Posted on Oct 16, 2010
Door will not lock light stays on
Usually this is caused by the door being bent, the hinges being bent, or a worn out door strike/catch not holding the door tightly closed. Lol, got kids?? Mommy's little helpers love to lean on the doors(the ones that open/close vertically). Also, slamming the dryer door can break the little plastic arm attached to the door switch--I see MANY switches with the arms broken in-half or the strikes/catches damaged from slamming. Usually a relatively simple repair to replace the strike/catch.
Aug 13, 2015 | Kenmore Dryers
Battery door dosen't stay closed
After you close the door hold it closed then slide it forward
Nov 19, 2013 | Nikon Coolpix L22 L-22 Black Digital...
My battery door cover doesn't stay closedbattery door
Push it closed with thumb .. hold closed..then slide forward
Volvo 850 door lock
Check child safety mechanism as well because that might be stopping from locking.
Nov 19, 2013 | Cars & Trucks
Camera does not stay on
Check battery charge is full.
Clean battery contacts with alcohol and an ear bud or electrical cleaner.
Make sure the door holding the battery in is securely closed.
If battery is not holding a charge, it could be time to buy a new one.
Jan 19, 2013 | Cameras
The door that holds the batteries in will not stay shut i believe maybe where you slide it shut a piece of that might be broken is there anyway to fix that or do i just need to hold it closed and hope for...
Pull the batteries out and see if it will stay closed, if it does the batteries are installed incorrectly. If it still won't stay closed your options are to either tape it shut or get a new camera unless it is under manufacture warrenty still or you have an accidental damage plan.
Jul 28, 2011 | Olympus FE-210 Digital Camera
The battery door catch has broken
On most cameras you can hold the catch closed with an elastic band around the body of the camera, if necessary with a small square of cardboard over the hatch itself, or several bands, if the hatch actually holds the batteries in place. At least you will be able to use the camera, even if it does look a bit untidy!
Dec 26, 2010 | Cameras
Fuji S5000 camera problem....The battery door will not latch because the cheap plastic retaining nipples inside the battery box have worn down/or broken. Tape will not even hold door closed! The retainers...
You could use a piece of velcro as a strap but I would start looking at ebay or other places for the parts to fix it. Sooner or later someone will sell it.
Mar 23, 2010 | Fuji FinePix S5000 Digital Camera
I dropped my Fujifilm s1000fd and the battery door wouldn't stay closed, so I had to tape it down for it to work, now it won't turn on at all, how can I fix it?
It is possible that because you had trouble with the battery door not staying closed the intermittent power from the batteries has blown the fuse inside. Thats just a guess tho but my S1000fd also has a damaged door catch and I drilled a hole through the battery door and glued a nut where the catch used to be on the top of the battery compartment and fastened the door with a screw. Job done.
To fix your power problem would involve finding the fuse, or what ever has failed. Search online for a repair manual - shouldn't cost too much
Nov 23, 2009 | Fuji FinePix S1000FD Digital Camera
Door
need to replace the catch
Oct 20, 2008 | Whirlpool GEW9200L Electric Dryer
Canon PowerShot A720 IS Digital Camera Logo
351 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
