Question about Acer TravelMate 2480 PC Notebook
Hi there to "THE GURU" My Acer laptop Travelmate 2480 shows no sign of life despite checking power supply via mains and battery supply. Voltages checked and measured. Completely disassembled now looking for the obvious fault (solder dry joint etc) Nothing found. Checked fan --- runs ok with seperate power supply to enable check. When sw on no power lights either mains or battery. No fan running. Completely dead. What is most commonly the problem with these models with the snags described above? Appreciated. Mike.
  • mikewaldburg Oct 16, 2010
    Good Day,
    Thanks for the advice. Will first have to assemble unit before applying your advice. This will be a while as time is a premium right now. Appreciated and will report back in a few days that, with a bit of luck, that the problem is solved. Regards. Mike.
  • 656 Answers
First remove the docking device if applicable power up on battery if no reset power again power up on battery if no power check the battery pin and clean the socket if it doesnt work plug to ac outlet if the led is still not working reaset the adaptor socket if possible replace the following components internal dc to dc converter internel ac adaptor even the processor board and system board or you can check ur laptop with a chiplevel technition because the vrm section in the board has been damaged if you know vrm section you can measure the voltage and chcek the components for damge and replace it while removing the components dont use a soldering iorn if you are familiar use a smd rework station or bga rework station soldering iorn can damage the circuit print also chek the power swith for damage and the power switch voltage shoul be 3.5v and 0v
if you want to know more please write to me in details as iam here to help you
Posted on Oct 16, 2010
  • rajesh raman
    rajesh raman Oct 17, 2010
    hay did the suggessions solve your problem
Recover acer travelmate 2480 password
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Dec 24, 2013 | Acer TravelMate 2480 Notebook
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
Acer 2480 2247 won't power up -no lights no nothing, pwr supply is not the problem,lid close switch isn't stuck ,pwr. on switch seems fine and power supply jack on motherboard is not broken
Remove the main battery and the power supply, allow several minutes to get rid of any residual charge, now plug the power supply adapter back in and press power "leave battery out" is there any change? if not! remove power supply, now! press and hold power for 60 seconds to reset the laptop. Next install main battery back in and the power supply adapter, power up! if no change, the motherboard is the problem.
Mar 07, 2011 | Acer TravelMate 2480-2779 Notebook
Hello, My TravelMate 3270 battery is not charging at all. Laptop shut down immediately the mains power is off. It is workin fine as long as the mains power is on. Battery indicator is yellow and...
Hi
it sounds as though the battery itself is come to the end of its life
you can buy replacements online at different stores or go to www.ebay.com and type in acer travelmate 3270 battery and search for different ones
good luck
hope you get sorted
Jan 28, 2011 | Acer Computers & Internet
Not powering up. even when plugged in overnight. no power.
hi there,
try to unplug every thing connected to the laptop, even the power supply. Now disconnect the battery. Now press and hold the power button for 30 seconds.
Reconnect the battery and power to the unit. now try to power on the machine.
You should be good to go.
In case that you still face the issue, i would recomend that you should visit the service center.
Jul 09, 2010 | Acer TravelMate 2480-2968 Notebook
Battery will not charge. Black box (on wire which connects to mains - sorry not good with techno!) light is on. Acer Travelmate 2480 laptop. Quite old I think, got it second hand. Does it just need a new...
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 04, 2010 | Acer TravelMate 2480 PC Notebook
Laptop wont switch on
Hi there!
Check your power supply 1st, in meantime check did you plugged your baterry in propperly?
By any circumstances if we are thinking that software is main problem ,laptop should at least boot up, but after those checkings , if your machine still dont work, then the problem is in hardware and you need service help.
Please rate solution! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Acer TravelMate 2480-2968 Notebook
No power
laptops don't powerup either because the battery isn't full, or it isn't plugged to the mains using the lead. if you think the above is fine then it must be because the laptops isn't accepting power in, either because of the motherboard has died, the chips have burned or the power button is faulty. if it's working using the battery but not using the charger then you need a DC socket repair. if it's plugged to the mains but there is no sign of any lights you're likely to have lost your motherboard. if your laptop does start but you see nothing on the screen its usualy the memory ram or the screen or the motherboard, plug it into an external screen and see what happens
this isn't something you can find a solution for in here, the best way is to take it to your repair shop
an independent one will do, or else I recommend a website which collects it and does it for you
cheaptofix.co.uk
I hope this helps. Please rate me.
>> www.laptopquestions.co.uk
Mar 08, 2009 | Acer TravelMate 2480-2968 Notebook
Acer travelmate 2480 does not turn on.
the metal rod is an internal part to the coaxial power coupling, which is normally soldered to the main board in the computer. Chances are you are going to be taking it in for repair. Good Luck!
Jan 09, 2009 | Acer Computers & Internet
Acer TravelMate 2480 PC Notebook Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
