Question about Compaq Computers & Internet
Can you please tell me the recommended resolution for Compaq MV7540 17 inch CRT monitor?
  • Compaq Master
  • 32,281 Answers
The recommended resolution depends upon your preference and the capabilities of you graphics card. I suggest you start with 1024x768.
At some resolution the image may be stretched and a circle may appear a slight oval shape. If this is annoying then adjust the resolution accordingly.
Posted on Oct 16, 2010
Machine boots and stops at compaq and then black srceen
Old computers can be cured with old tricks... No that doesn't sound right. You probably set your resolution so high that your monitor does not register.
A solution includes pressing F8 on boot until you hear a beep (That means, "I got it, stop pushing" and select Enable VGA Mode. This will enable basic video driver reset to 640x480; because your computer is so old, you should stick with 1024x768 as your highest resolution for a 15 inch CRT or LCD. Always check the manual of the monitor for what resolutions it supports. Your PC cannot even accept another monitor. Specs seem antiquated. Please invest in a new PC soon.
Dec 16, 2013 | Compaq Evo D31vm Pd1092 Pc - No OS -...
Compaq fs740 text too faint and fuzzy to read well
Firstly you need to switch to the monitor's optimal resolution of 1024x768 @ 85Hz and before anyone posts anything about resolution 1024x768 @ 85Hz is the optimum not the maximum. To change to this resolution: Assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1024x768 and then click Apply. Also in Display settings you'll find an advanced button, in the advanced panel you'll see the option to adjust the refresh rate, try adjusting this to 85Hz. Now press the Menu Button on the front of the monitor and press + of - until you see an option called "Degauss" and press the select button on the front of the monitor, your screen will do a disturbing jump and flicker accompanied by a metallic thud, this is normal. If this doesn't help message back.
Aug 26, 2007 | Compaq fs740 17" CRT Monitor
Compaq FS 7600 - display - CRT - 17" driver
click start control panel you will see thre options change theme change desktop background and adjust screen resolution then select resolution from the drop down list you can adjust to your preffered settings 1024x 768 is usually recomended (you have not stated your problem)
hope this helps
Sep 22, 2011 | HP Compaq FS7600 17" CRT Monitor
Well i have a 23 inch LG monitor and im using the recommended resolution of 1920 x 1080 and its not fitting the screen. therers 1 inch black border on tob and bottom and 3/4 inch black border right and...
Dear User,
Good Day!
Please use the auto button in you monitor then it will automatically adjust the resolution of your screen. Please feedback us what happen.
Thank you...
Apr 16, 2011 | Computers & Internet
My HP Compaq LCD Screen (17 inches) has intermittent or no video
ur vga cable may be defected 100% chance for cable or tft screen may be
my email sushilverma150@gmail.com
Mar 24, 2010 | HP Compaq FS7600 17" CRT Monitor
Installing new LCD monitor on Compaq. Getting error messsage :Analog Out of range 88.6 Khx, / 85Hz Please help Already tried to install any necessary drivers Mike
Your old monitor muts have been a CRT type. Reboot the PC into safe mode (hitting F8 key during boot up), then set the resolution to be 640 x 480 @60Hz. Then reboot, then readjust the resolution again to the native resolution of your new monitor (I cannot tell what that is since you do not give the make and model of the monitor), make sure to leave the refresh rate at 60Hz.
Jan 22, 2010 | Computers & Internet
My compaq 5500 monitor is not changing its resolution
The video driver may have reverted to a standard VGA driver or your
video driver has stop working and needs reinstalling.
Sep 20, 2009 | HP Compaq MV 5500 15" CRT Monitor
Less H-width for higher resolutions
this is not the electronic problem, this monitor is made to support such (800x600) resolution.
Dec 17, 2008 | Compaq 7500 17" CRT Monitor
Colors around the edges wrong now I cleaned the inside of modem out
monitor is damaged I recommend replacement with a lighter more efficient flat panel of any size.
Oct 25, 2007 | Compaq CV 7500 17" CRT Monitor
Black vertical belt in both side
This sounds as if you havent got the correct resolution of your desktop. Either there will be an auto adjust button to press on your monitor menu or you will need to Right click on your desktop>properties>settings Tab and change resolution to 1024 x 768 or similair to change the desktop size, or maybe reduce to 800 x 600 then click apply.
Dec 08, 2006 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
163 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
