All object lost proportion.They are wider and/or lower than they should be
  • 32,281 Answers
Wide screen monitors can distort the images. At some resolution the image may be stretched and a circle may appear a slight oval shape I suggest you start with 1024x768 and increase the resolution till you get a well proportion image. The best way to do this is to draw a circle and when you change the resolution you can see the proportion od the image.
Posted on Oct 16, 2010
  • 4,737 Answers
Please clarify, You problem is under the Motherboard category, but the description doesn't seem related to motherboard, or is it? Let me know with more details. I assume it's an issue with your computer.
Thanks.
One wheel stoping 3 wheels r not i think its the proportion valve. there r no leaks and the mastercylinder has not lost any fluid. could that b the problem?
No. Typically the proportioning valve only controls prake bias front and rear. Need more info to more accurately determine the issue
Jan 30, 2013 | Cars & Trucks
Error light blinking Citizen -S300 printer
  • High-speed (200 mm/s) printing
  • Longer cutter life (2 million cuts) delivers lower maintenance costs
  • Greater reliability delivers longer life & lower maintenance costs
  • Wider paper width allows printing of additional information & larger fonts
  • Interchangeable interfaces
  • 2D barcode (QR-code and PDF417) support allows wider applications
  • Built in buzzer provides audible alert without adding extra cost devices
  • Built in power supply eliminates unsightly "brick" and frees up space
  • Cash drawer kick-out external device port supports 2 cash drawers
  • 2-color printing supported (when specified paper uused)
Aug 16, 2011 | Citizen CT-S300 Printer
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
How to use the depth of field
Hi Michelle,
"Depth Of Field" (or DOF) is the amount of distance both in front and behind the point of focus that is also in focus. If there is a very short distance or range of an area that is in focus, it is said to have a shallow depth of field. This shallow DOF is achieved by setting the aperture or "f stop" to the wider or lower number settings. The smallest f stop number will provide the shallowest DOF. The DOF will become broader ir deeper with each increasing f stop setting.
Shallow DOF settings are often used in portraits where the background is desired to be blurred. It is also used in macro (extreme close up) photography, and anywhere a blurred foreground / background is desired.
The down side of this is that the shutter speed will increase proportionately, to maintain a properly exposed image. If you are trying to convey a sense of motion - by allowing the subject to be blurred slightly - you'll have some trouble due to the fast shutter speed. Neutral density filters fixed to the lens can correct this. The other side of the coin is in an indoor and evening outdoor photography. If you're not using a flash, you'll likely have to be shooting more towards the "open end" of the lens (more towards the lower number aperture settings) which while allowing enough light for an good exposure - will also reduce the DOF. Some people or objects in front of and behind the focus point will not be a sharp as a result.
The best thing to do is experiment. set a number of object on a surface - 2', 3' 4' 5' and 6' away from the camera. A tripod or other solid surface can help a great deal. Set the camera up for a "normal" exposure in a full manual or Aperture Priority Mode of the middle object 4 feet away. Take a picture. Next, open the aperture (make the number smaller) and adjust the shutter (if in manual) to expose properly again. Take the picture. Keep doing this both BOTH directions for the aperture from the first "Normal" exposure. Compare the results to see exactly how the DOF changes. Tinker with shutter speeds - or don't change them. Notice that with each time you open the f stop, the shutter must speed up to compensate for more light entering the camera due to the wider aperture setting (and vice versa).
I hope I understood your question correctly and that this helped.
Oct 11, 2010 | Cameras
Display is narrow with space on either side
change the resolution to one that is for your display ...probably you have a wider format and you choose a resolution that is made for a 3/4 built display ...if you have a wider model ...you have to change the proportions ...try one with bigger differences like 1280 /768 or something like this ...try one by one until fits cause on laptop you do not have monitor controls...
Nov 23, 2009 | Toshiba Satellite L305-S5907 Laptop
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
Image stretched
No offense, but if you're an IT ignoramus, you should know how to fix this. I see you said 2 monitors, did you see that you could've added display to the second monitor making it look out of proportion? A simple fix is either adjust resolution, disconnect second monitor, or you could do the hardest one, test every single component related to display until you find the problem. Good luck with the last one,if you come down to it.
May 07, 2009 | Dell Computers & Internet
Alignment problems
I'm not sure of which telescope and finder you have but I can give you some general instructions.
If your finder scope is is the type that is like a tiny telescope then you should see a set of cross hairs when you look into it. The goal is so that when the object is in the center of the cross hairs you should be able to find it in your telescope eyepiece.. To do this you need to align the finder scope,
I usually use a terrestrial object to do this. I use these because they don't move like stars do. You can choose road sign, a spot on a tree or a street light though that can disturb your night vision. Aim your finder at this object and center it in the finder. Check to see if it is in the eyepiece of your telescope. Use a low power eyepiece to give you a wider field. The low power eyepieces have higher numbers such as 25mm. If the object is not in your eyepiece find it and center it. Check your finder again. You need to adjust the finder so that the object is in the center of the cross hairs.
There are usually 1 to 3 thumb screws to adjust this. If there a three you go back and forth until it is centered. Check your eyepiece again to make sure the scope is still centered. You can use a higher power eyepiece (lower number) to refine this since it displays a narrower field. Just repeat the process.
Once this is done, you find the object in the sky in your finder and center it and it should be there in your eyepiece.
Clear skies!
-jodair
Mar 20, 2009 | Optics
All pictures appear wider than they really are
You may have to match up the video card settings with the monitor settings to get the correct resolution setting. Try adjusting the resolution of the graphics card to match the setting for the monitor. If this does not work you can call, Envision customer support at this telephone number : 1-888-838-6388. They should be able to help you get the correct setting for you set-up. I hope this information helps you with your problem.
Dec 03, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Elongated desktop and software screen images
Many graphic cards enable you to rotate the screen up to 360 degrees. You could try to post this question again under you graphic card model instead of computer screen model as it is your graphic card that is certainly the problem.
Jul 25, 2006 | Microsoft ChiMei CMV938D 19" Widescreen...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
