Question about Refrigerators
How do I change the door from left opening to left
  • 1 more comment
  • micky bird Jun 03, 2008
    The gasket around my sub zero model 532 is already worn out. Where can I purchase this gasket
  • sharon641 Aug 07, 2008
    I too want to change the door so it opens the other way round. the instruction manual is awful - it impossible to understand what is meant by the pictures.
  • bigkush Oct 07, 2008
    I want to change the direction of the way my frig opens but I cannot figure out how the get the handle off so that it will make sense with the new direction
    Scholar:
  • 110 Answers
Fox appliance parts in atlanta, or appliance parts depot in waco texas
Posted on Jun 03, 2008
How do I switch the door opening to the other side? I would like to change the dryer door opening from the left side to the right side. By looking at the dryer it appears this is possible.
Hello, Frazer -
Without knowing the make and model of you clothes dryer, it is a challenge to provide you with the precise directions for changing the swing of your dryer door. With that being said, this YouTube video may prove helpful to you: https://www.youtube.com/watch?v=VW9183PsCLc .
How did I find the YouTube video? Using Google I entered the following search statement, with quotation marks, as indicated: "clothes dryer door swing" .
This web page with written directions may also prove helpful:
http://homeguides.sfgate.com/change-dryer-door-left-right-66754.html .
Best wishes.
Dec 17, 2017 | Dryers
Can anyone let me know how to swap the door opening
check with the manufacturer's tech support . some can not be changed over .
Aug 07, 2015 | Refrigerators
Blizzard lb 1ss upright freezer change door opening
Under the bottom hinge, unbolt it, remove plastic plugs on other side of door, transfer hinges over and door handle, refit the lower one in new position, put plastic plugs in old holes
Mar 12, 2013 | Freezers
Headlight On alarm sounds every time you open the driver door in a 2002 Intrepid.
put the key in the drivers door and turn to unlock, that should disarm it.
Oct 01, 2012 | 2002 Dodge Intrepid
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
I have liftmasterPro garage door opener. How do i
You cannot change the code of the opener without purchasing new remotes and not using your existing remotes. To change the code of the keypad locate the smart/learn button just to the left of all those white wires. Press and immediately release this and then walk over and key in any 4 digit number and press enter.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Refrigerators Logo
417 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
