Question about Sony PlayStation® 3 (60 GB) Console
I bought a ps3 console from my cousin yesterday..he included in d package 2 wireless controllers a power cable & an AV chord...when i was to test the unit..no video is appearing from my tv..i interchanged the av chord with my previous av chord (ps2) but still nothing happened..i tried to test it on a different tv but still no video..what do you think is the problem of the console? according to my cousin before he sold it to me its completely working..what should i do?
  • 104 Answers
  1. this sucks it scared me when it happened to me but the fix is simple
  2. Put ps3 in stand by mode
  3. Hold power button till it beebs 2 times
  4. go to reset output or somthing of that nature
  5. You should have video if not let me know and ill find a fix.
Posted on Oct 16, 2010
My mad catz controller will not configure to my ps3.How can i do it wireless?
sir good day there are two way on how to configure your wireless controller to your ps3 console.... the automatic pairing and a manual pairing
first way an automatic pairing
1.turn on your ps3..
2.Connect the smaller end of the included USB cable to the PS3 controller.
3.Connect the opposite end into either USB port on the front of the PS3.
The pair light on the PS3 will flash. When it stabilizes, you can disconnect the USB cable
and use the controller wirelessly.
second way a manual pairing
1.. turn your ps3..
3.Connect the opposite end into either USB port on the front of the PS3. Press the "PS" button on the center of the PS3 controller. The pair light on the controller will flash. When it stabilizes, you can disconnect the USB cable and use the controller wirelessly.
you can try that 2 way on how to configure your controller to your ps3 console if this help you please rate me thank you sir..
Jun 12, 2011 | Mad Catz Call of Duty Black Ops...
Non-working ps3
hold the power button till it beeps twice , that will reset the settings , if it does come on then go to manual settings ,av settings, make sure ur tv is hdmi if u choose this option and choose either 720 dpi or 1080 if ur tv is full hd , if not do not choose these if ur using an av lead instead of a hdmi
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
Every time i connect my av. chord it gives me the e74 but when its just the pwer chord it works ive bought a new av chord it has the same thing showing up
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Feb 18, 2010 | Microsoft Xbox 360 Console
Wireless connection 4 ps3
go to network settings,scan for router,accept your cousins router name then follow on screen instructions.hope this helps
Jan 24, 2010 | Sony Playstation 3 (PS3) Console
Playstaion Shows only in black white
Try manually resetting the video.
While the PS3 is off,
Press and HOLD down the POWER BUTTON
When you hear the second beep, QUICKLY release the power button.
Let me know what happens.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't work after installing MGS4?
How did you turn it off? Did you use the"hard switch" in the back of the ps3, or the soft power button in front?
My ps3 locks up on occasion, and have to turn it off with the hard switch in the back.
If that doesn't work try this:
Turn off the ps3 with the hard switch, then hold your finger on the soft power button in the front while turning the hard switch to the on position. Hold your finger on the front power button for about 10 secs, this should reset your vid settings.
Hopefully this is helpful to you.
Sep 25, 2008 | Sony Playstation 3 (PS3) Console
Ps3 80 gig
Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
40gb hdmi
I had the same problem at first. I did the following:
1. Connect both cables: Multi-AV and HDMI.
2. Go to the TV's channel for SCART.
3. You now can see the PS3. Go to Display Settings, under
Settings menu. Select HDMI and the desired resolution.
4. Change to the HDMI channel.
5. You should now also see the PS3's XMB on the HDMI channel.
6. You can now disconnect the Multi-AV.
I hope this information can help you and your customer.
Please rate.
P.S. I figured you were Dutch since you used Neophyte as a name for your previous question. Are you Dutch, and in that case: what videogames store you work at?
Greetings,
DarkNeogen.
Jan 30, 2008 | Sony Playstation 3 (PS3) Console
Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Dec 10, 2007 | Sony Playstation 3 (PS3) Console
Picture goes to a lime green fuzz and then no piture or sound!
which AV connection are you using? HDMI or the cable supplied with the PS3, If using HDMI, you have to set the PS3 visual settings to HDMI, to do this, use the cable supplied with the PS3, and have the HDMI cable plugged in. Then while using the cables supplied with the PS3, switch the settings over to HDMI, then change the TV's input selector to your HDMI and confirm the settings changes. Hope it helps take care
Oct 17, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
