Lexmark X4270 All-In-One InkJet Printer Logo
Posted on Oct 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't install my printer I have a mac What can I do?
Anonymous
Level 3:
  • Master 386 Answers
  • Posted on Oct 16, 2010
Anonymous
Master
Level 3:
Answers
386
Questions
0
Helped
130308
Points
1549
Hi Good day!!
Here are the step to install printer in your Mac:
Open up System Preferences. Select Print & Fax.
Click on the + button to add a printer.
Go to http://lpr.byu.edu/printers/.
Click the desired printer.
Click the Properties link on the left of the page.
Select and copy the last half of the Network Name (everything after http://lpr.byu.edu/).
In this example, you would copy printers/N362ESCD/.printer.
Go back to the Printer Browser.
Select the IP printing tab at the top of the window.
From the Protocol: drop-down menu, choose Internet Printing Protocol - IPP.
In the Address: box type lpr.byu.edu:80.
In the Queue: box enter what you copied from the previous step.
Type the name you want the printer to have in the Name: box.
Choose Generic PostScript Printer from the Print Using: drop down.
Click Add.
The printer should be added to the printer list and is now ready to be printed to.
I cannot connect my canon pixma printer TS3166 to my MAC what can i do
on Mac go to
https://www.canon.com.au/support/sims-content?pid=a0a145a4c3434ac6b847d981e931fdeb&cid=BE0B6CFFD79B4A9AAE0012A61030E408&ctype=ap
download driver for Mac
download on mac install on mac .
apple should find the printer if MAC is connected to same IP network once the driver is installed .
don't download from a windows p.c !
must be a MAC to get correct file system for Mac .
might also need scanner software
https://www.canon.com.au/support/sims-content?pid=a0a145a4c3434ac6b847d981e931fdeb&cid=1F9EDEE31B294C8FB08459C57FB0A9E4&ctype=ap
this is a photo organiser for MAC
https://www.canon.com.au/support/sims-content?pid=a0a145a4c3434ac6b847d981e931fdeb&cid=25AEEE420C60439EBBD93B12FCA060FB&ctype=ap
I have actually installed networked printer on an Apple System and as long as MAC and printer are on same ip network it should detect the printer once the driver is installed on the MAC
2answers
How do I get my canon ip6000 printer to recognize my Mac computer
You need to go on your mac and download the driver and install it on your mac.
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/ip-series/pixma-ip6000d
Assuming printer only has UBS interface Mac should recognise the printer is connected to it once you install the driver .
If it has an internet protocol ip address tcp/IP then give printer an ip address in the range of the MAC and it will be detected by the mac.
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
2answers
How to install used HP C4480printer into MAC have no install disc
Sure install the disk with the drivers and select for mac
follow the instructions then connect the USB to your mac and finish the install
Dont forget the power cord
1helpful
2answers
Need to install Lexmark X4550 but only have MAC disc am on vista
Are you trying to install the Lexmark X4550 to your Mac computer? What is the exact OS of your Mac (i.e 10.3.x; 10.4.x or 10.5.x)?
You have to make sure that the pinter is compatible with the OS that you have.
I don't have a doubt with the printer since you mentioned that it worked with XP. To install the printer to your Mac, please follow the steps below:
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
If the printer will not work, you may download the driver from the Web and install it. Here, I have provided you the link where you can download the printer driver:
http://www.findmysoft.com/drivers/Lexmark-X4550-1-0-11-1-printer-driver.html
Just click the download button and install it.
Have a great day!
2answers
Driver-mac
you need to use generic driver for MAC... What kind of MAC OS are you using? MAC 10 have the drivers installed on the computer and you don't need to install the software.
Macbook, lexmark f4270 driver
Apparently, the drivers for your printer is bundled in with the MAC OS CD. There are no MAC drivers on the Lexmark for your model. And the 4200 series should work.
Follow the instructions below.
Installing the bundled driver
Plug and Play
Steps Action 1 Power on the printer. 2 Plug the USB cable into the printer and into the Mac. 3 The Mac OS will automatically create the printer queue and install the printer.
Manual installation
If you plugged in the USB cable and the print queue was not created, follow these steps:
Steps Action Illustration 1 Plug the USB cable into the printer and into the Mac. ... 2 Launch System Preferences and select Print & Fax. Image 3 Click + to add the printer. Image 4 Select the printer, click Print Using and select your printer from the list. Then click Add to create the printer object. Image 5 Once the printer has been added, close System Preferences. The printer is now ready to print. Image
Troubleshooting
If you installed the driver from the printer·s installation CD or from a web download, uninstall it and follow the instructions below for recovering the driver from the Mac OS 10.5 (Leopard) CD.
Steps Action Illustration 1 Uninstall the installed driver. ... 2 Delete the Lexmark folder found in Library/Printers.
... 3
Insert the Mac OS 10.5 (Leopard) CD to recover the bundled driver and then click Optional Installs. Image 4 Click Optional Installs.mpkg. Image 5 Go through the installation process. ... 6 In the Optional Installs screen, select first Printer Drivers and then Lexmark Printer Drivers. Image 7 Click Continue and complete the installation process. ...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Lost installtion disc
Hi there, you can download some installer online for you printer machine, just type this link to your browser:
http://www.lostmydrivers.com/printers-drivers/lexmark/
and please find below details on a bit middle part of the html page, click download. Make sure the your printer wire are plugged and use it as your default printer and have it test. Thanks. Have a nice day.
Regards,
fixyaqueen.
LEXMARK LEXMARK P4350 PRINTER V.1.0.6 MAC OS X 10.2.3 MAC OS X 10.2.4 MAC OS X 10.2.5 MAC OS X 10
Lexmark P4350 printer Driver for Mac OS X 10.2.3 - 1...
Licence: Freeware
OS: Mac OS X 10.2.3, Mac OS X 10.2.4, Mac OS X 10.2.5,
Size: 20 MB 07/13/2007 173 -
download now
Lost installation disc
Licence: Freeware
Regards,
fixyaqueen.
I need to install HP deskjet 6940 on my Powerbook G4. I am operating on MAX OSX 10.4.6
  7. Click Add.
How to add a network printer (AppleTalk or LPR)
Adding an AppleTalk or LPR network printer is very similar to adding a USB printer. In Step 4 above, you would choose AppleTalk or "LPR Printers using IP" from the pop-up menu. From there, the setup differs slightly.
AppleTalk printer
  • AppleTalk must be enabled in Network preferences.
  • If your network uses AppleTalk zones, choose one from a second pop-up menu that appears.
  • Make sure to avoid potential issues with AppleTalk multi-homing.
LPR printer
  • You must enter the printer's IP address or DNS name.
  • If you're printing to a queue, deselect the checkbox for "Use Default Queue on Server", then type the queue's name. If not, leave the checkbox selected.
  • You can select your printer from the Printer Model menu or leave it at Generic. In essence, are selecting a PPD file.
Question mark appears, or trouble finding a printer?
If you can't find the printer you want to add in the list of connection methods, make sure you're choosing the right connection type for your printer. Some printers may use custom input-output modules, such as "Epson AppleTalk". You may need to select one of these custom options in order to add your printer. If there's a question mark on the printer's icon, or Print Center or Print Setup Utility lists it as unsupported, check for an updated software version at the manufacturer's website, or the Mac OS X downloads page.
Tip for software installation
Your printer may appear in the printer list before manufacturer-required software is installed. If you have such a printer, remove the printer from your printer list before installing the software. Add the printer back to the list after you've installed the software.
Printers whose drivers or PPDs are included with Mac OS X
Additional Information See these articles for lists of printer drivers and PPD files included with Mac OS X:
25587: Mac OS X 10.3: Included PPDs for PostScript Printers
25588: Mac OS X 10.3: Raster (Inkjet) Printer Drivers Included
107001: Mac OS X 10.2: Included Ink Jet Printer Drivers
107002: Mac OS X 10.2: Included PPDs and Use of PostScript Printers
106490: Mac OS X 10.1: Many Third-Party Ink Jet Printer Drivers Are Included
106516: Mac OS X 10.1: Includes PPDs for Many PostScript Printers
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
