Where do I find the filter on my Kleenmaid washing machine. I would like to clean the filter.
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now I am sure the only filters on your machine are the ones that in your inlet hoses for the water.Are you getting a lot of lint on your washing?Sorry to ask you this question but why do you need to clean the filter,Is it because of the lint build up?Please reply with additional information and if it is because of lint I will reply back with a method of removing it when I receive your posting.Looking forward to your reply.
Posted on Oct 16, 2010
  • 38 Answers
SOURCE: washing machine
take the top piece off by hand. Below that should be a plastic cover hiding a bolt. Lift up this plastic cover and remove bolt. Lift agitator up. Might have to wiggle it a bit.
Posted on Jun 22, 2008
SOURCE: Kleenmaid top loader Washing Machine Mod KAW 793W leaking
Problem turned out to be a leak from the top, not the bottom and was caused by debris blocking an overflow trap
Posted on Aug 07, 2008
  • 410 Answers
SOURCE: How do I take off the agitator in my kleenmaid
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
SOURCE: washing machine wont drain have cleaned filter
the waters not coming out the mechine
Posted on Dec 19, 2009
SOURCE: is there a filter on the wmt 03 hotpoint washing machine
We have the same machine which had the same problem, there is no filter only a colection pot at the bottom of the machine. Unfortunately even cleaning this did not solve ours, in the end I had to strip the machine down, split the drum down and then flush the brown crud which had accumulated behind the steel inner drum. Ta da problem solved!. Probably not what you'd want to do if you were not confident in attempting it but it saves buying a new machine.
Posted on Feb 07, 2010
My kleenmaid ked600 condenser dryer is giving me a F4 error code. And not heating. Could it be the thermostat? Where can I locate the meaning of the error codes ?
In case of F0, F1, F2, F3, F4 failures,
contact your service technician without
hesitation.
http://www.kleenmaid-appliances.com.au/assets/pre2011_manuals/Use&Care/DR/KM_DR/KED600.pdf
and then I found this
"F4? Too much lint in the lint filter, front housing, or in the condenser Clean lint from lint filter and/or condenser I would just contact them.
http://www.kleenmaid-appliances.com.au/support/contact-us/
Mar 04, 2016 | Dryers
I have a kleenmaid washing machine its about 30 yrs old and still runs well but it is now leaking oil from under the adjitator how do i fix it.
Sounds like the seal for the transmission is leaking oil through the seal. You will need to remove the tub or turn the machine upside down to remove the transmission and replace the seal. That is if the seal is still made.
Nov 17, 2015 | Washing Machines
Kleenmaid LWK74AW-3050. How do I clean the pipe/hose from the back of the washing machine to the tub??
Inlet hoses connected To washer have a screen trap in them disconnect and clean.
Oct 22, 2015 | Washing Machines
Kleenmaid kfl 1506 manual required
You can view and download your manual in PDF format at this address.
http://www.kleenmaid-appliances.com.au/use&care/WM/kleenmaid/KFL1506_660448en.pdf
just copy and paste it into your address bar.
Apr 30, 2011 | Washing Machines
What causes "Error 4" to
Hi, googled this problem myself and found this page. Doesn't help much though. Will still have to get someone out to look at it.
http://kleenmaid-appliances.com.au/TSPM/WM/Kleenmaid/KFL1600_Fault_Codes%2040220415.pdf
Good luck, we'll need it now our warranties are useless.
Dec 04, 2010 | Washing Machines
Material chord lodged around agitator of kleenmaid KAW393 washer
sorry to saybut you would probley need to stripp down most of the unit...to remove chord.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can you tell us what error 6 is as displayed on Kleenmaid KFL1600 front loading washing machine. We have the manual and it is not listed. Many thanks
Hi I've got a KFL1600 with error 6 too - I fixed this once by cleaning the filter, but now it's come up again and the filter is clean. Not sure if it's related but the door has stopped unlocking too and we have to open it by pulling the little tag in the filter door. Very reticent to get it repaired as everyone says that these machines are a nightmare and costly.
Jun 20, 2009 | Washing Machines
Need part for electrical mother board
You can now order Kleenmaid service parts at www.edis.com.au. Login to their online shop with the user name "retail"and password as given on the login page. Search for the parts you are looking for.
I successfully purchased and received spare parts for a Kleenmaid dishwasher this way.
Apr 29, 2009 | Washing Machines
Kleenmaid mocel kaw651wq3050
It is located at the end of the broad hose that comes down from the bottom of your tub.
Jul 31, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
