Question about Exercise & Fitness
Health stream treadmll error E1 please advise
  • 3,530 Answers
E1 Means that the treadmill can't read the speed value.
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Click on this link for the illustration.
Thank you for using Fixya!
Posted on Oct 16, 2010
Fix error 2 treadmill
this is a probably a faulty sensor speed see the diagram attached. However depend of your mark , model, can be e1 ,tight the connector very well, and clean it. Test the s.speed for open or faulty.
Oct 19, 2013 | Exercise & Fitness
E1 error on LG washing machine LD-1204W1
Hi gmann947,
*Nice nickname, reminds me of Jeremy Mansfield, a retired radio presenter on 94.7 fm - Hehe*
To help you with your request, I'd advise you to look at my Tip below, it has the full description on how to fix the E1 error:
L.G DISHWASHER E1 ERROR...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it.
Jul 21, 2011 | LG Dishwashers
Hi My dishwasher is coming up with the error E1 I can not find my manual Can you please advise what E1 means Thank you Mary
It would have been helpful to know which model dishwasher you have got.
Refer this site for all typical error codes for fisher and paykel. I am assuming for your model E1 would been door is not closing properly. Could be a swollen door seal or simply the latch not engaging properly with door close microswitch.
Hope this helps.
Feb 20, 2011 | Fisher and Paykel Dishwashers
I have a v-fit kik-036-11 and keep getting e-1
Your problem might be a magnet that has fallen off from within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jun 02, 2010 | Exercise & Fitness
Error Message E1 Dries for 3 minutes then stops and gives the error message
E1 means open thermistor. Clean lint duct assembly and blower. Make sure you have good air stream from the vent outside. If this doesn’t help, replace the thermistor.
Oct 17, 2009 | Kenmore Dryers
What does error 3 on my microlife blood pressure monitor mean?
I have digital blood pressure monitor Model 302 made in japan. It is not working. when start shoes error 3. Please advise
Jun 28, 2009 | Microlife 3AC1-PC Blood Pressure Monitor
Dryer will not stay running through entire cycle or it will just stop before clothers are dry and sometimes get a E1 error message. Mostly it will just stop and clothes are not dry, times that is runs...
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
Jan 02, 2008 | Kenmore Elite HE4 Electric Dryer
Exercise & Fitness Logo
1,198 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
