Question about Toymax Magnavox 37MF331D 37 in. LCD TV
2200uf 25v can be replaced with a 2200uf 35 v for a magnavox lcd tv
    Problem Solver:
Yes, just did one works great. If my research is right this circuit is actually 29 volts. destined to fail from the get go.
Posted on Nov 11, 2010
Is a 2200uf 10v cap better then a 1000uf 25v in a samsung tv with clicking problems and wont turn on
The word is than, so the phrase is "better than"
2200uF is fine, but wasted where only 1000uF is needed.
10v where 25v is required is a big problem. For DIY repair jobs where you are just replacing parts, never under spec the voltage of a capacitor. You can go a little higher, but never, ever go less.
If you want to put in a better part, choose a decent make such as Panasonic, and go for a 105 deg C Low ESR component.
Sep 05, 2014 | Televison & Video
Powers on and off by itself. I took the PS board out and it looks like caps cm811 and cm817 are domed slightly.
Replaced them with the same value, but slightly high voltage rating. Ex.: 1000uf 10v -> 1000uf 16v... 2200uf 16v -> 2200uf 25v.
Mar 15, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
TV WON'T TURN ON......KEEPS ON TRYING BUT WON'T TURN ON Samsung 72 in lcd
CK capacitors on power supply Board if any of them are puffed up on top they are Bad most of the time they will be 2200uf 25v or 1000uf 16v
Dec 02, 2009 | Televison & Video
37mf23id magnavox takes 15 min to come on . its a magnavox which is made by philips
You need to replace the power board,Or replace the capactors on it.
Replacing the capactors is the best idea.They are under rated at 10volt insted of 16volt or higher. They cost less too. If you replace the board,you will still have the same problem again later. They are usualy 680uf 10v,1000uf 10v,2200uf 10v,and 3300uf 10v. Replace them with the same uf but 16v or 25v EXPANPLE use... 1000uf 16v or 1000uf 25v
They are polorised Blak spot on board is the - side of cap. Stripe on cap is -. The caps. swell if they are bad. The tops round out,or the X on top breaks anfand black or brown goo comes out. Top should be flat. It I can assist you further please feel free to ask. toddthetvmd@yahoo.com
Oct 27, 2009 | Philips Televison & Video
Over temp red light fashes
Check and replace the following on the smps:
Cs-860 & Cm-860 1500uf/10v With 2200uf/16v
Cm-856,Cm-858,Cs-859,Cs-861 With 1000uf/25v
Replaced Cm-854 & Cs-857 With 2200uf/25v
then let me know if it will power on...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Samsung HL-S5679W 56" HDTV
I have a 52" hdtv monitor/dvd player, Model D52W27DYX1 and have been playing NetFlex dvd's on it for 5 years. This past week, after I inserted a dvd, this popped up.."This disc is incompatible with this...
Hi, thank you for visit fix ya.
After insert DVD on your tv, cut off?, or all the time the tv don't work?.
If so, replace capacitors on power supply.
2200uf 25V, 220uf 25V, upgrade to 35 V.
Thank you
Jul 24, 2009 | Televison & Video
Replaced flyback a month ago and it worked fine. Now it the power light started blinking. Takes like 45 min to get it to come on. Whats wrong now
replace the power/deflection pcb which has the
flyback on it.go to encompass.com to see if
available or try shop jimmy parts.com.
Jul 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
37mf321d
Try to replace the Small Signal Board (SSB Assy) of your tv.
Jan 01, 2008 | Philips Magnavox 42MF521D/37 Television
Toymax Magnavox 37MF331D 37 in. LCD TV Logo
196 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
Paul
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
