Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer comes up with error code 6a80 message. i have a cannon mx700
  • Canon Master
  • 3,530 Answers
Try this first. Please go to this link.
If the above did not work, try the second solution below:
1. Please open the printer cover and when the carriage head moves to center pull out the power cord.
2. The Purge unit is on the right side. Use a flashlight and you will see two ink pads. This is where the print-head is PARKED and is the top of the Purge unit.
3. There you will find wiper blades that move from the rear to the front. They wipe the bottom of the print-head when it is parked.
(The ink pads actually drop down about 3/4" to allow the wiper blade to pass and then it is supposed to spring back to the rear. Also the ink suction for cleaning the print-head is done by the purge unit.)
4. Use some rubber gloves and a paper towel and see if you can press the ink pads down just a little bit - about 1/4". See if for some reason the wiper blade is stuck extended, if so see if you can get it unstuck. Please do this gently such that you don't break anything there.
This error indicates that the purge unit is not giving the correct timing signal as it rotates inside 360 degrees. Therefore, something is either broken or jammed inside. If you had a paper jam and tried to forcefully pull it out, you could have pulled the internal gears out of alignment.
So you will need to do some maneuvers to try to release the cartridge from its parking position. Again, don't try hard.
Now, if this does not work than it would be cheaper to buy a new printer rather than sending it to Canon for repair if its not in warranty
Posted on Oct 16, 2010
My cannon printer MX700 just now paper have jam inside. After i taken out of paper that jam inside my cannon printer have a error of 6A80 and it can't fixed. Pls help. Thanks.
The 6A80 indicates that the mechanism called the `purge unit' does not work correctly. In some cases after a paper jam, some paper gets in the unit. Try this:
Turn on the unit and open the cover. Hopefully, the printhead will come to the center. If it doesn't, unplug the printer and try to move the printhead by hand, to the left. Do not force it. If you are able, get a flashlight and inspect the area inside the unit to the right. There may be bits of paper in that area. Being careful, remove it with a tweezers or some such tool.
If you cannot see anything, then the machine will need to be dismantled for service. I recommend authorized service.
Sep 20, 2010 | Canon MX700 Office All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
My wife printed 3 pictures and then printer gave her a error code 6A80. I checked on error code and it said possible paper jam. I then looked inside the printed from the back to front and seen nothing....
This is sort of scenario could be caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Dec 14, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
MX700 ERROR 6A80
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Error 6A80 – means “AP position error”- indicates that "an error occurred in the APP motor during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Hope this helps
Aug 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannon Mx700 error code 6a80.
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
Nov 27, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
