Question about Vacuums
Simons steam iron domina1000 instruction manual Thank you.
  • 2,382 Answers
Hi, the instruction manual for the Simons Steam Iron Domina 1000 and other Simons product are not available online but you can get them by contacting Simons directly on 02-8338-8660..
Posted on Oct 16, 2010
I have a model #4268-126 Iron, can't find my instructions to clean the iron, have very hard water and the steam does not work very well please help Thank you.
as with most electrical appliances that use water they need descaleing every so often, use a store bought descaler, read the instructions before useing/buying.
Sep 03, 2011 | Vacuums
I need instructions on how to clean Digital Advantage Iron. I have lost my manual.
any iron can be cleaned by running a little water and vinegar through it several times, it loosens the scale build up that gets in all irons over time, be sure and try to clean out the venting steam holes in the face of the iron, Once you do this, run clean clear water through it and you should be fine, if possible, always use bottled water (purified) water in irons
Jun 02, 2011 | Vacuums
Scrunci steamer no steam when the button (for steam) is pressed Vinegar has been used to no avail. Please advise. Thank you
Its most likely this iron is clogged with lime scale as you have already used Vinegar . Buy a lime scale remover liquid , mix it with hot water. And pour it into iron leave for 24 hours then empty , clean iron out to get rid of any lime scale solution. And try it again..
Hope this helps.
Apr 14, 2011 | Scunci 52067 Handheld Steam Vacuum
Steam isnt coming out of my iron as it should be any ideas thank you
It may be bunged up with cal or bits. Fill the iron then heat it up to full heat, unplug. Then over a sink discharge the steam from the bottom in one go. Or buy a special cleaner.
Mar 24, 2011 | Vacuums
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1485 . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
I just bought a Tfal Ultimate Autoclean iron FV 9450. I am reading through the manual and trying to figure out all the parts and functions. I cannot figure out how to remove the anti calc valve. I...
Anti-calc valve wings (grip) located at #3 of the 1-15 labeled description diagram that is part of the instruction manual. The wings are on either side of the dry/steam control #4. Lift up on the wings (grips) and the dry/steam control will accompany it. The anti-calc valve is under this control. It's easy once you realize where the silly thing is actually located.
Jan 15, 2011 | Vacuums
My daughter purchased a Steam iron Make
Don a thermo fuse can generally be bought at an electronics parts store or Radio Shack type outlet in the hobby parts area. Like any other fuse they are rated specific to the requirement of the appliance, do NOT use a higher temp one.. If you have warranty, ( likely 1 year???), return the iron, If you replace it, it is generally an in line crimp. I would only attempt it once as the iron may be defective.
Sep 11, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
