Question about Oster 76076-010 Hair Trimmer
Oster76 i got the bottom off the clipper how do i take out the motor it feels like somethings holding it
    Problem Solver:
  • 4 Answers
You have an lock ring holding it in place ..remove the lock ring with lock ring pliers..bscafeful when you remove the armature First remove the brushes .
Posted on Jun 22, 2008
My clipper smoked and now it wont run at all
Sounds like your motor went out. You might as well buy new clippers for the price to fix them. One thing that causes that is when you spray your coolant to not hold your clippers blade up. Keep them blade down. The coolant can run into your clippers and burn them up. You only want to use grease inside your clippers.
Jan 21, 2013 | Andis Agc Super 2-speed Clipper...
I have an Oster Golden A-5 one speed that I bought 20 yrs ago. I have lost the manual and need to know if I can oil this unit and if so how? Thanks, Lorrietis
Here how you can oil your A-5 clipper, The button on the side of the clipper is the oiler, depress the button down with a small screw driver and while holding the button down, use Oster clipper oil it will take about 4 to 5 drops of oil. after you are finish wipe clean with paper towel and turn on your clipper, let it run for about 2 minutes. Turn your clipper off and you are done. We hope this will help you Thank You. Manny's Sharpening www.mannyssharpening.com
Apr 20, 2011 | Oster Golden A5 1-Speed Universal Motor...
My clippers are frozen. They don't vibrate but the motor turns on.
Hi, How long have you been using the clippers? In my experience they can get clogged with hair quite quickly depending on the animal. I'd recommend removing the blade to better get at the hair stuck between the blades. Once the blade is off lubricate the appropriate parts following the guide in your operating manual. It's best to do this soon before the motor burns out. If you feel that the blades are too clogged, it's easy to buy a replacement blade for around 1/3 the price of a new clipper set.
Mar 12, 2011 | Andis Super Deluxe Pet Clipper Kit
Oster A-5 Golden clipper blade is not flush against the clipper so wont clip you have to hold the blade down tight so it will clip.
see if the blade and hinge have moved away from the body of the clipper, the two screws either side of the hinge assembly may need tightening, or the main body may need replacing,
If its just one blade then there must be a problem with that blade.
Oct 19, 2010 | Oster Golden A5 2-Speed Universal Motor...
How do you put on a blade when you took it off?
There is a picture of an oster clipper in the picture so I assume you are talking about an A5 style blade/clipper. Hold the clipper with the hinge facing you, if the hinge is open, then turn the blade so the blade number is facing up and slide it onto the open hinge, start the clipper and push the blade down to shut it. If the hinge is not open, prize it open with a flat head screwdriver. www.sheaeaseltd.com
Jul 12, 2010 | Oster Golden A5 2-Speed Universal Motor...
Blades fell off oster dog clippers but can't fit them back on. Please help !!
Assuming that you did not damage anything, the blades should go back on easily.
Slide the blade onto the hinged flat 'post'. Turn the clipper on. Fold closed the blade assembly into position against the clipper body.
If this does not ork, you must have damaged something.
Mar 27, 2010 | Oster Golden A5 2-Speed Universal Motor...
When I turn it on it chatters The clippers get very hot quickly and I don't know were the grease and oil are used on the clippers. A friend gave me the clippers with no book of directions. help thank you...
OK AS FAR AS OIL YOU CAN OIL THE BLADES, AND ON THE SIDE OF THE CLIPPERS THERE IS A STRAIGHT SLOT TENSION SCREW TURN IT ON AND ADJUST THE SCREW TO THE PROPER SOUND AND FEEL THEN THE MOTOR WILL SLOW DOWN AND NOT GET SO HOT SO QUICK. I HOPE THIS HELPS.
IF THIS DOES HELP CAN YOU RATE MY ANSWER?
(I GUESS IT IS IMPORTANT FOR THIS SITE)
Feb 22, 2010 | Oster Golden A5 2-Speed Universal Motor...
A5 dog clipper or blades may need tune up or
some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact mannyssharpening@yahoo.com
Oster Golden A5 keep turning themselves off whilst I'm clipping
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
Feb 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76076-010 Hair Trimmer Logo
55 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
