Question about Fisher and Paykel WL37T26D Top Load Washer
Need to remove the agitator off a Aquasmart. Belt stuck under the agitastor
reg501
  • 413 Answers
SOURCE: Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
Posted on Dec 25, 2008
dragonsthatk
  • 547 Answers
SOURCE: coin under the kenmore elite oasis agitator, how do i remove it
remove cap at top of cone unscrew
Posted on Feb 12, 2009
  • 234 Answers
SOURCE: How do I take out the agitator?
I'm not sure if this is the same as your machine but here is a link to a possible solution:
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
I hope that this solves your problem.
Posted on Apr 15, 2009
I believe for that model, to remove the agitator you must reach inside with both hands and firmly grasp the lower part of the agitator and pull straight up. It may be a little difficult but should come off. Make sure you get it all the way back down when putting it back on. Hope this helps.
Posted on Apr 23, 2009
srsrs_1999
  • 9 Answers
SOURCE: Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Posted on Apr 30, 2009
How to clean machine
what are you wanting to clean?? most places are the pump & bowl under the agitator..
the pump is under the machine, some have a little plastic side hatch you open to get to the pump.
the bow is gotten to but removing the agitator, usually a thumb nut down the middle of agitator, and then pull up agitator to remove out the top,
soak up all the water & clean out the dirt & scale you find.
Feb 20, 2014 | Fisher and Paykel Aquasmart wl80t65c
Item caught under agitator
The top of the washer pulls up. IT may be hard to do. This will expose the whole drum so that you can see around it. If you need to remove the agitator, there is a cap on the top of the center, take it off and you should see a nut and some lock washers, Remove the nut and lift the agitator out.
Dec 19, 2013 | GE Washing Machines
Something is stuck underneath the agitator in m Fisher & Paykal Aquasmart. How do I remove the agitator?
Hi - with aquasmarts there is a plastic dome like fitting in the middle of the agitator & unscrew this to remove the unit.
Jul 08, 2011 | Fisher and Paykel WL37T26D Top Load Washer
Is there a way to remove the agitator? I have a belt stuck under the agitator?
Jdangullet --
Yes, the agitator assembly can be removed. The WPRE6100G parts diagram is available at: [http://www.geappliances.com/] The top plastic portion of the agitator can be removed to access the screw [SCR 1/4-20 MCH HXW 5/8 S] securing the coupling assembly. If you have questions, write back. -- SWT
Aug 22, 2010 | GE Profile WPRE6100G Top Load Washer
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
Apr 15, 2009 | Washing Machines
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Remove the agitator
Dec 25, 2008 | GE WBSR3140DW Top Load Washer
How to remove the agitator??
remove agitator cap ,,looking down in agitator removre the plastic seal with a firm yank,,now you can see the agitator hold down nut,,remove that bolt with 1/2 inch nut driver or wrekit,,pull agitator..if clothes is jammin it down take you belt and slide under agitator,,and pull booth ends ,,but away from your fast ,may come up fast..always unplug
Oct 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Fisher and Paykel WL37T26D Top Load Washer Logo
352 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
