Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
Fridge My refridgerater is not getting as cold as it did last week...it is approx. 10 years old.
  • 868 Answers
Check your door gaskets for any gap that can allow warm air into the doors.
Posted on Jun 03, 2008
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool 10 cu ft fridge, freezing cans of pop at rear center of unit and spraying interior. Have had the fridge over a year with no problems until the last couple of weeks.
Turn the cold control down. If you have already have the cold control turned down then you will need to replace the cold control/thermostat with a new one.
Aug 03, 2011 | Whirlpool Refrigerators
Fridge not cooling. Freezer OK. it is about 10 years old. It was playing up a few weeks ago; not keeping cool. But now no cooling at all.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Refrigerators
Hi, I have a Hotpoint RLA51 larder style 'frost free' fridge. Its approx 6 years old. For the past 3 years its been frosting up meaning every 8 weeks we have to defrost it manually. I bought a new...
high chris
check to see if you have a drain at back/near bottom of the fridge,if so, clean out with neat clorine bleach.if you have a fridge thermometer adjust fridge to run at +5c(optimum temp) and cover all food with cling film to cut down on condensation.
regards
geoff.
Aug 26, 2010 | Refrigerators
Fridge and freezer not staying cold - Got home last night and my whirlpool (frost free) fridge/freezer was switched on (power running to it - light etc working) but was not chilling properly. Everything in...
This can happen if the fan motor in the freezer compartment is bad. Causes the freezer section to freeze up and you will not get air circulating, so no cooling. Check the fanmotor
Nov 06, 2009 | Cars & Trucks
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Mar 27, 2009 | Refrigerators
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water Logo
61 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
