When i turn my dell on, it turns on loads and then a black screen with error code 0f00 131b msg block 875
  • 3 Answers
Your hard drive needs to be replaced. You have a bad block in the boot sector. Try to boot up in safe mode (F8) if same thing happens you need to replace your hard drive and start over. If you can get it to boot up in safe mode run check disk on hard drive, that may fix it. Hopefully you have a back up somewhere? If you need help with the check disk let me know. Hope this helps,
Julie D
Posted on Oct 16, 2010
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Dell Laptop Vista repair stuck! My Dell Vostro 1500 does not start. It is Vista Home. So, I am trying to repair it with the installation disk. However, the installation stuck after the "Windows is loading...
leerobin
It does look like you may have a problem with the hard drive on the computer.
In regards to recovering your data if you have access to another computer you can connect the hard drive to it to see if the data is recoverable. Note since you ran the system recovery it may have over written your data. If this is the case then you might check with your local computer store to see if they have a hard drive data recovery program. As long as there is not a physical problem with the drive they may be able to recover the formatted data.
After that I would look at the top of the drive to see who the manufacture of the drive is then download there diag and repair tool for the hard drive. While you have the drive on the computer run a repair scan on the drive. If you just have some bad sectors then the diag program will zero them out and repair the drive. If the drive is indeed bad the program will tell you this as well.
If the drive is bad and your computer is still in warranty then you should be able to get Dell to send you a replacement hard drive. If you are not sure if you are still in warranty let me know the service tag of your computer and I can look it up for you. Also note you will want to have Dell send you your recovery CD if you do not already have it.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 20, 2010 | Computers & Internet
I changed hard drives and now I can't load my programs back on
ok thanks for you prompt reply.
when you say laptop not reading HDD it allows you to see dell logo but after that there should be a msg an error msg saying no boot device been found..or just a black screen?
check BIOS if hdd is detected. if yes then it means windows is problem probably but we need to double check on this. run diags on the hdd alone use the dell diags disc. check if you get erorr code. running the diags is like this. keep tapping on F12 after seeing dell logo then insert disc when you see the options. select cd dvd rom drive then press enter then run diags custom test for hdd.
Dec 08, 2009 | Dell Latitude D505 Notebook
Dell D630LCD inverter error, unable to turn lamp ON/OFF.
hi,
the interal graphics adaptor is making trouble, to find aóut if it just with your screen, hook up another external monitor and boot up.
Still the problem?
then you wil have to (let) the graphics card (be) replace(d), definitely.
Good luck
Sep 07, 2009 | Dell Inspiron 6400 Notebook
Error code 0244
Hi there.
Error Code 0F00:0244
"Msg Block 5*****4: Uncorrectable data error code or media is write protected"
Sorry to say the hard drive has failed or is corrupt with bad sectors, with these Dell drives there is no way of fixing them.
There maybe a possibility that you can recover your data if it still spins up and you add it to another computer as a slave device.
Good luck and thanks for using FixYa!!
May 20, 2009 | Dell Computers & Internet
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Error Code: 1000-0146
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
