Question about ViewSonic VX2235wm LCD Monitor
I have 2 vx2235wm, just over a year old. Within a month of each other I had to replace caps to get black screen to live again. Now, I have just acquired a pink vertical line on 1 monitor, top to bottom.Any ideas. Thanks!
  • 11,361 Answers
Solid vertical line means you have bad LCD panel due to failed TFT driving circuits.
This VX series are not built as well as the old Viewsonic used to be.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Oct 17, 2010
My vizio VO47 L has a black screen and sound. I do get a light on the vizio logo on the front. I see no illumination coming out of the back of the unit. what is wrong?
Power Supply popped a cap and fried the metal resistor bank. Replace the cap C241 and solderer the resistor bank. Worked for two months then pop out again. This time the resistor bank burnt through. Bought a new power supply DPS-38cp-1a from ShopJimmi.com $56.00 Replace supply which lasted 1 year 1 day and the same thing happen. Same components. Got this TV free but its costing me time and money now.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
When I turn On my monitor, it is displaying black screen after the message "No Signal - Analog" (normal/usual message). When I disconnect the VGA cable from the monitor, it shows the message and...
The VX series are cheaply made with cheap caps and they failed due to bad caps, see my pictures here: http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX2235W/
VX2235 came out years (2006) ago so I cannot see that it will be only 8 months old. I fixed many of these VX series.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | ViewSonic VX2235WM Monitor
LCD model viewSonic vx2235wm 6 months out of warranty, When powered up, the backlight will flash, but then screen is dark. The blue light at the bottom is on and Vista recognizes the monitor. Sometimes, I...
Are you sure about no bad caps? The top of the caps have to be completely flat, and bad caps can also look normal but can have high ESR, you will need meter that can read ESR of the caps.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Post the pictures of the board and caps.
Sep 05, 2010 | ViewSonic VX2235wm LCD Monitor
Black screen
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | ViewSonic VX2235WM Monitor
My veiw sonic flat screen is black the light on
If "NEW" return it for replacement up to at least a year. Just hope you have kept prove of payment or payment slip?
Nov 01, 2009 | ViewSonic VX2235wm LCD Monitor
Apple ibook crashed when on MS Word. Black screen fan running???
Sounds like you have a problem with the logic board. This appears to be a common problem with iBook G4 related to the fit of the logic board (ie motherboard) within the case.If you were to take it to apple store the likely fix would be to replace the entire logic board which is very expensive and probably not fiscally sound on a 5 year old machine. Another option would be to try to fix it yourself. If you are feeling brave you can dissemble the laptop and attempt to shimmy the logic board back into position.
Here's a link that detail the approach. http://www.coreyarnold.org/ibook/. This guy had success on two ibooks that had the same problem and they have been working for 2 years since he did his repair
Also, here is a link to a forum that may offer you a few more approaches to solving your problem. iBook G4 won't boot up - fan running & black screen - AppleNova Forums
Hope this helps, good luck!
Mar 30, 2009 | Apple iBook G4 14-INCH Series M7701LL/A...
MAG Innovision LT2219WDB monitor will turn on -picture up clear as ever and 2 seconds screen goes black, turn it on and off screen comes up clear as always and 2 seconds goes black. will not keep the...
I have the same problem with a customer's monitor (LT716S); it turned out to be damaged power supply board. As I understand it, MAG has a 3 year warranty on parts, will probably charge you a flat labor fee plus shipping. If you do not have your purchase documentation for warranty, dump it and replace. If you can, then you may wish to have it repaired.
My customer replaced theirs; I am trying to purchase replacement parts to repair...good luck.
Feb 24, 2009 | Computers & Internet
Viewsonic vx2235wm display issues
There are many areas of the LCD monitor that can cause very much the same effect that you see. Most of the time there are capacitors that go defective.
The caps can be tested with an ESR meter. This is a time consuming job. The caps are mostly surface mount types, and will require the proper tools to change them.
Normaly the service centers will change the defective boards rather than try to service them. There is no component level service support for any of these monitors.
In the end, it would be cheaper for you to replace the monitor rather than to fix it.
Jerry G.
Jun 02, 2008 | ViewSonic VX2235wm LCD Monitor
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Sep 08, 2007 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
216 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
