Question about Whirlpool Duet GHW9150P Front Load Washer
Hi, i have a front load washer and the problem is i turn the power on, all the lights turns on when i push the start button the power shuts off . I also unpluged the washer for 5 min it still does the same if u have any advice for me.
    New Friend:
Check to see if the screws on the bottom panel are tight.
Posted on Dec 04, 2012
  • winansicis
    winansicis Dec 04, 2012
  • 618 Answers
Sounds like the main controller or the touch pad called the interface.
Posted on Oct 16, 2010
The Dryer won't start. Power light just flashes red on and off
There are too many problems that it could be, anything from the Button going bad, to the Door Shut Switch being defective, to the Motor, Relay inside the circuit board, to loose wire during the move, and the list goes on and on. Unless you can test each component that sends the START signal, nobody will be able to assist you with the information you have provided.
Mar 01, 2014 | Hotpoint Ariston AWD129 Front Load...
I had the main water shut off and forgot to turn it on before starting my machine. Now it is stuck. I unplugged it for a couple hours, then plugged it back in and the lights just blink and the cancel...
try this:
Press "Stop" two times.
Push "Power."
Select the button for the desired wash cycle.
Press the appropriate "Modifiers" and "Options" buttons to adjust the settings.
Push "Start."
thanks to here
Mar 06, 2011 | Kenmore Elite 45986 Front Load Washer
How do i reset my kenmore he 2 washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2010 | Kenmore HE2 Plus Front Load Washer
I have an HE2 Elite Kenmore front load washer. I
Sounds like a control board issue. Not much else for you to do but wait
Eric
Nov 19, 2009 | Kenmore Washing Machines
Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
If that machine was so easily damaged (the electronics in particular) it is a sorry design.  About the only thing I would suggest is to actually pull the AC plug and ignore it over night.  Whatever safety 'feature' caused the door to lock, may reset itself if given enough time.
And yes, Sears service is not as wonderful as they claim.
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Whirlpool Duet GHW9150P Front Load Washer Logo
62 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
