Question about Radio Shack 3 Pack 60 Minute Audio Cassette Tapes
I have a set of Optimus 900MHz wireless headphones PRO-100. i need a new battery with service which used to be done by Radio Shack, this time when attempted it was denied
Mechanic688
  • 204 Answers
SOURCE: RADIO SHACK SCANNER pro -92/NEED SCHEMATICS >>help
Looking at a site, I noticed there are 3 versions of that scanner. 200-0522, 200-0522A and 200-0522B version. The 0522 has the earlier firmware, and the A version upgraded this.
Possibly they can help at the RS support site.
http://support.radioshack.com/support_tutorials/communications/cfq-2000522.htm
Good luck with this, Mechanic
Posted on Jan 13, 2008
Mechanic688
  • 204 Answers
SOURCE: Antenna for radio shack pro 2018
Hello, Radio Shack would be the first place i'd try for a replacement. Mechanic
Posted on Nov 01, 2008
smartr10U
  • 1305 Answers
SOURCE: Need instructions on programing Radio Shack Pro 94
Radio Shack has a website will ALL their manuals... Click HERE and you'll find the pro94 on the list and it will give you a full manual.
Have a blast!
Posted on May 25, 2009
smartr10U
  • 1305 Answers
SOURCE: need instructions on how to program
You can get the owner's manual for your scanner by clicking HERE
have fun...
Posted on May 26, 2009
smartr10U
  • 1305 Answers
SOURCE: PRO-60 RADIO SHACK SCANNER
Here is the lin to the manual download... CLICK HERE
Posted on May 31, 2009
Drove 70 miles to a different time zone - constantly searching for service
THERE ARE TWO TYPES OF TOWER SYSTEMS FOR CELL PHONE SERVICE A OR B. TRY SWITCHING TO THE OTHER. ALSO TAKE IT TO A LOCAL RADIO SHACK AND THEY CAN DO IT FOR YOU. GOOD LUCK.
Apr 09, 2015 | LG New L38C Optimus Dynamic CDMA Wireless...
I have an Optimus wireless headphone device. The battery pack gets constant corrosion it causes the battery to leak. Bought it at Radio shack but they said to contact the parent company which is Opti
only one way to really stop that, someone has to get it apart and scrape all the stuff off the battery contacts (I use a knife and even a small file and then use baking soda to prevent the return--you can use a car battery spray made for this or even tranmission fluid will do it. once clean and protected (especially clean the contacts where they touch the battery) keep a eye, what happened is a battery was left to long or on way too long and leaked on the contacts.
Dec 18, 2012 | Televison & Video
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
I haveolder radio shack 900mhz stereo head phones. it says it uses nimh 3.6volt 280mAh battery pack. I cannot find a replacement any where. Any help would be greatly appreciated.
Most of the battery can be build and replace. Look at specialist like onlybatteries.com where you can buy any kind of battery cells, with tabs if need that you can weld, or make weld at your local electronic shop repair. Keeps the old pack, open it with a xacto without breaking it or a dremel and check how its made. its usually AA nimh battery...
Oct 07, 2009 | RCA WHP141 Consumer Headphones
900MHZ CHARGING LIGHT STAYS RED AND DOES NOT GO OFF
Didyou try taking the battery out of the headphone and replacing it? This may act as a reset and allow charging. I'm assuming that these headphones are not brand new, and that you are lining up the arrow on the one side with the arrow on the charging base. This is the only way the inductive charging can occur. Good luck!
Dec 22, 2008 | Sony Camcorder/Audio/Video 900MHz Wireless...
Battery holder for Pro 95 scanner
Your pro 95 takes the same yellow rechargable battery pack as the pro 97. It is available at the site listing below. It is their #100-006. It cost 5.99 plus 10.95 shipping. I ordered it 4 days ago and got it two days ago. You may be able to save on shipping by calling them and requesting some sort of slower shipping.
https://www.greamerica.com/shop/cgi-bin/cp-app.cgi?usr=51F4658914&rnd=7881653&rrc=N&affl=&cip=71.106.150.99&act=&aff=&pg=prod&ref=100-006&cat=Radio+Scanner+Accessories&catstr=HOME:Radio+Scanner+Accessories
Nov 07, 2008 | Radio Shack Pro-95 Handheld Scanner
Optimus 900MHz Pro 100 wireless audio
there is an adjustment on the back middle. If it is connected to a audio source, the red light should light up on the front.
Then there is an adjusting dial next to the volume turn that until you get the sound you want.
Good luck
Aug 12, 2008 | Audio Players & Recorders
Radio Shack Headphones 900mhz
You can download the instruction manual here.
http://66.77.167.109/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_HEADPHONES&ACTION_PRODUCT_ID=WHP141
Mar 23, 2008 | RCA WHP141 Consumer Headphones
Radio Shack 3 Pack  60 Minute Audio Cassette Tapes Logo
98 people viewed this question
Top Radio Shack Electronics - Others Experts
Are you a Radio Shack Electronics - Other Expert? Answer questions, earn points and help others
