Question about Motorola Mobility V9 Cell Phone
My phone only charge with usb cable, the wall cable is not working, please help !!!
  • 4 Answers
First of all, find out whether there is any fault in your phone. Do connect your USB Wall Charger with another phone to check its working. If it is not working that means you need to buy a new one. You can purchase it online as it will not take too much time or offline as per suitability. Choose a charger with the best quality and prescribed for your set.
my phone only charge with usb cable, the wall - 31p8q9tcyll._sl500_ac_ss350_-iskyujrvhg5wobe4wz4y5ohd-3-0.jpg
Posted on Nov 23, 2017
  • 1,188 Answers
You probably need a new wall charger. The wall and the computer USB deliver 5 volts to the phone, so it sounds as if your wall charger is the problem.
Posted on Oct 16, 2010
It charges somtmes but only 26% now it wont charge and wont turn on i have changed cords and plugs nothing works please help
1. is there lint or some pants pocket debris or dirt inside the charging port on the bottom of the phone? use something non metal that won't break inside, it needs to be thin enough to move around and poke around the bottom, not interfering with the chip that sticks out.
charges-somtmes-but-only-26-now-wont-c42sdu52tip34gjoftdmfcql-4-0.png before you do that.. turn off the phone and take out the battery just in case. you don't want to short the charging port, so why risk it.
you can use a thin side wooden tooth pick (not the thick rounded ones, they won't fit), or you can use an unused plastic brush tooth pick that's available at most stores like Walgreens, CVS, Safeway, etc..
2. If nothing comes out, try using a different wall charger adapter that works for your Samsung device. Many cell phones use a 3volt charger that won't work with Samsung smartphones because Galaxy phones need a 5volt charger. The others will just trickle charge it or may not work at all. Also, the cord itself. You can't just use any micro USB charging cable. You need to use one that can push enough electricity to your device. So it has to be a Samsung smartphone compatible one. If you have ruled this out..
3. Is the wall outlet bad? Try a different wall outlet. Example: at the airport we tried all the wall outlets in the same area, none of those charged the device. We thought it could be the charging cable or the adapter that was dead. Then we went to another area in the airport and tried again. This time we were charging the phone fine. Cable and charging adapter were apparently working great.
4. If that's not it.. what happens when you try jiggling the charging cable connected to the phone.. try angling the cable head to the left or right.. does it only charge when in a specific position? it could be the charging cable or the charging port that needs fixing..
5. If that was not the case, and everything you've tried doesn't work, it could just be the charging port on the phone is bad. Bring it to your local cellular repair shop. It should cost around $35 to $50 to fix.
6. If your phone is not worth it to fix it, it might be a better idea to buy a newer model phone. If you can't afford another phone or to fix the port, why not just buy a separate battery wall charger. You can buy a cheap China version to charge your existing battery outside of the phone and then just pop the fully charged battery in when you need to use the phone. I'd recommend charging the battery when you are sleeping.
The attached link is to an eBay listing that has a compatible wall charger sold in the US for $5.99 shipped free
LCD Battery Charger for Samsung Galaxy Mini GT S5570 i5510 S7230 S5330...
Nov 10, 2015 | Samsung Galaxy GT-S5570
Tip
How to convert a USB Battery Charge Cable to AC
<p>Many of the new battery-operated devices such as phones and MP3 players come with USB cables to charge the battery while the computer. However, wall chargers for these items are missing, damaged or undelivered. If so, you can use a USB wall charger, USB cables, adapters and because all have the same size at the end with these boots are endless. <br /> <p><br /> <p>Generic Battery <br /> <p>1. Buy a USB wall charger. These are available online through www.amazon.com and www.bixnet.com or a limited number of electronics stores like Radio Shack or Best Buy. <br /> <p><br /> <p>2. Connect the USB end of cable to the USB wall charger. <br /> <p><br /> <p>3. Connect the charger to the USB cable. Then connect it to the wall. The machine starts working the green light. <br /> <p><br /> <p>iPod Battery <br /> <p>1. Connect the USB cable to the iPod. Be sure to press the two ends before inserting it into the iPod. If you do not, you can damage the pins, once that happens, you will not be able to charge your iPod. <br /> <p><br /> <p>2. Mount the USB wall charger sliding the top in half, for the manual. <br /> <p><br /> <p>3. Connect the USB cable for both USB wall charger. Plug the wall charger. The costs start when the lights come back on the iPod screen and you will see the battery icon fill. You can find this anywhere iPod charger are supplied. <br />
on Aug 09, 2011 | Apple iPod touch
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
My casio rock wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 31, 2012 | Casio G'zOne Rock Cell Phone
IPhone charging not supported with this accessory
First Option:
Second Option:
Jul 30, 2012 | Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME...
Hello i m using nokia 5530. my mobile is not charging from pc computer on usb cable. please give me a solution thanks
Sorry to read about your problem, I hope this helps you out.
First, try and use the in wall power adapter that came with your phone, if that works..That will tell you, that your USB cable defective, If your in wall adapter, does not work..you have a charging circuit problem
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Nokia Cell Phones
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
Why will my phone not power on? The let stays solid while charging but will not power on
are you trying to charge the phone with the wall charger or the USB cable. if it is the USB cable then chk if the USB port both on the laptop and the hand held is faulty or not, then chk if the USB cable is faulty or not. if you are to charge through the wall charger then check if the charge is faulty if every thing this is fine then get chk the battery.
Aug 07, 2009 | RIM BlackBerry 8800
Phone not turning on
first use the wall charger and see if the problem is not your battery in the phone. if the problem still exists, then uninstall and reinstall the driver for phone in the computer. if the problem still exists then you have a bad usb cable. please rate this thanks
Sep 15, 2008 | Orange SPV M3100 Smartphone
Motorola Mobility V9 Cell Phone Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
