Question about LG Washing Machines
Makes a noise like a jack hammer on spin,now for about 18 months is not getting worse
  • 44 Answers
Probably the rear bearing is is no good. Check if there is any up and down movement in the inner basket or if by spinning the inner drum by hand if there is any noise.
Posted on Oct 16, 2010
My ford festiva makes a loud whining road noise. Recently the gearbox was changed, and 3 months before that the lhs front wheel bearing was replaced. Any ideas what the problem is?
that has all the hallmarks of a faulty or worn wheel bearing. Run the car on the road, come home and jack up all 4 wheels. Spin them and see if they feel rough, hold the top and bottom of the tyre and see if you get movement in and out.
The trick with replacing wheel bearings, is to tighten down whilst spinning the wheel until it locks up, and then release, if i remember correctly a quarter turn. Locking it up makes sure the bearing is fully seated. If not, they become very loose in a short time and the rollers in the bearing start to shatter. Ruined two before I was told that trick by the parts store.
Apr 08, 2017 | Ford Festiva Cars & Trucks
Dropped Canon EFS lens now makes clicking sound when zooming in and out
Take it to a repair facility, but it may be expensive
May 26, 2017 | Canon Cameras
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Water hammer makes a loud vibrating noise when filling
Hey- most hammer is removed by simply replacing the water valve. Have solved this way many times. Exceptions required spring suppressors on lines to faucets. Valves run about 40-60$ and are easy to install. Let me know if this info helps- have more if needed- Thanks- Ed
May 13, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Makes weird noise while auto-focusing
The 18-135 lens focus system is driven by a motor in the lens itself. So there are moving parts inside it, not really gears and pinions and such, but similar. If it works fine and doesn't make the focus jumpy or stick anywhere, it's probably safe to wait a bit and see if it either goes away or gets worse. If it gets worse or the focus jumps, you just need to take the lens in and have it serviced. The mechanism could be out of alignment or need other adjustment.
Jan 09, 2010 | Nikon D80 Digital Camera with 18-135mm...
Noise when high speed spin cycle
maytag washer makes a noise when washing or spinning. sounds like a screw is stuck or maybe a bearing is going. It is getting worse each day.
Dec 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
My 2001 chevy blazer makes humming noise when i drive. i just put new tires on the front and the had alignment fixed. noise is progessively getting worse.
Are the front tires the exact same size as the rear tires .different size tires can cause a binding in the transfer case.
Nov 05, 2009 | 1995 Chevrolet Suburban
My truck makes a grinding noise when turning to left. I have replaced all front end parts, but the grinding got worse. Is this a wheel bearing?
Hi
You need to jack up that wheel and spin it by hand, if you hear the similar noise it is most likely a noisy wheel bearing. Also if you have revently driven over loose metal road could be stone lodged in disc assembly. Could also be the wear indicators on the disc pads "telling you" that the pads are nearly worn out.
Hope this helps cbacer
Aug 11, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Loud clack on shutdown
Unfortunately it is probably the Sprag Clutch. My '95 did that for a while. Then it got worse and started making the noise during starting.
Nov 10, 2008 | 2003 Triumph Thunderbird Sport
Dewalt 18 volt cordless hammer drill
You should try to charge the battery again. Or you can try to fix it or then its time to get a new battery.
May 10, 2008 | Dewalt 18 Volt Compact Drill Kit
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
