Question about Cameras
I have a Tascam HD-P2. I only have one microphone. Is there a way to record stereo (L and R) sound onto one microphone?
    Brigadier General:
  • 11,967 Answers
Stereo microphones are available. Try minidisco.com
Posted on Oct 16, 2010
I have a DP2 Tascam 8 track recorder. Can I come out of my 16 channel mixer into my recorder and record my whole band?
The Tascam DP-02 can only record two tracks at a time.
You will have to mix "on-the-fly" and record the master out, or record each instrument seperately, and just record the drums as a stereo mix.
Feb 13, 2010 | Tascam Starter Pack for 4-Track Cassette...
I have a Tascam DP-02(not 01) and need to seperate songs
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Apr 10, 2009 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD
Unfortunately it's pretty much impossible to get a recording to sound like anything produced commercially these days without using lots of compression. Your burned CD problems might be the result of a faulty burner on your DP01-FX/CD. I have a 2488 and I still export all my mastered songs as wav files and burn them onto disc using my PC just because of the flexibility on the PC and you can control settings better which can cause disc burning problems (not to mention that the burner is newer and faster on my PC).
If you don't want to work on a PC you could look into replacing the burner in your Tascam. It is similar to replacing a PC's burner and the either the Tascam site and/or the Tascam Forum should be able to provide you with the specs and a list of compatible CD burners.
To get the final product to sound louder you could invest in an external compressor (a good used one should run you less than $100). You'll have to use the DP01's send loops to route a bounce of the stereo mix out to the compressor and then route the result back into the DP01 inputs and record on a couple of free tracks.
Hope this helps.
Cheers
bd.
Oct 14, 2008 | Tascam DP01 All-In-One Recording Package...
How to record from a microphone to a CD
Are you plugging a mic (if so what type) directly into the Tascam, if so this will not work.
will offer solution when you provide details of mic. There are no dedicated mic inputs on the CC-222mkIII unit.
Oct 07, 2008 | Tascam CC-222mkIII CD Player / Recorder
L and r mic input
no u only need one microphone.Set it to stereo recording
Jul 20, 2008 | Tascam US-122 Sound Card
Sound
No sound during recording ? No sound during playback ? Both ?
Do you have signal levels on the meters at stereo/ main out ? If yes then make sure master fader is at adequate level then check to see if there's a headhone on/ off switch or a headhone volume level  knob, if so then adjust ( be careful not to have the master fader at a high level when you turn on the headphones, it hurts )  If you don't have signal on the stereo/ main out meters or you do and the above steps didn't work then we'll take it from there.
Jun 21, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam us 144
make sure you select it as the interface device in cubase.
Thanks,
Nate
Mar 27, 2008 | Tascam DP01 All-In-One Recording Package...
Software.
I don't believe any software comes with the DP-01.  After you record your tracks, you have to "export" them to your FAT drive.  Once they are on your FAT drive, you will be able to see them using Windows Explorer.  Your Tascam shows up as a removable disk.  Simply open the drive and you will see the available folders.  The WAV folder will contain your exported .WAV files and you can drag&drop from there.
If you don't have the manual, you can find it online.  It's free!
Oct 24, 2007 | Tascam DP01 All-In-One Recording Package...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
