Question about Mitsubishi WS-65511 65" Rear Projection Television
Willtab; I found and adjusted the knobs and at first the image was perfece after 5 minutes the blue shadow lines showed again, do you have any other sugestion ???
    Genius:
  • 1,126 Answers
Convergence problem.
The convergence IC's need change, or you need a new convergence board.
You can get The IC's at www.mcmelectronics.com or a new convergence board at www.partstore.com
Posted on Oct 16, 2010
Set clock on a jvc kd-r330
It's very simple even if you don't have the owners manual.
Step 1: Hold in the Menu button until "DEMO" shows on the display screen.
Step 2: Scroll with the volume knob until it says clock. Then press the volume knob to select it.
Step 3: Scroll with the volume knob until it says "CLOCK SET." Then press the volume knob again.
Step 4: Then adjust the hour first by scrolling with the volume knob. Once the correct hours shows press the volume knob and it will move on to the minutes.
Step 5: Once the hour and minute is chosen push the menu button again to finish the procedure.
Nov 13, 2013 | JVC Kdr330
Blue and Yellow shadows on people and words
Open the front panel, till you see three knobs, adjust those knobs till you get the right picture again.
Jul 19, 2010 | Zenith R57W46 57" Rear Projection...
1. My Sony KP-57WS500 TV is turning blue after abut 3 minutesof operation. It stays that way for about 30 miunes and comes back with pictures again, but with predominatly blue color. 2. Sometimes the TV...
Sounds like the picture tubes are failing,common on sony. do you notice any thin horizontal lines? You mite get lucky and be able to adjust the voltages. Remove back cover and look inside to see which tubes are lighting up.The front panel below the screen will come off and behind it is a small access cover.remove it. there you will find the voltage controls (its a plastic square with 6 knobs). 2 knobs for each tube, 1 is focus the other is the voltage labeled "screen". they are marked so look closely. Green is always in the middle but sometimes they flip the controls for red and blue so pay attention to which you are controlling .slowly adjust screen voltages to see if you can get it to stay on. If you over do it those thin horizontal lines will pop up and the tv will shut off again. If you already have lines back off the voltage by turning knob to the left slowly until they diappear. If that seems to fix it but the problem but it comes back later, then the tubes are shot. good luck!
Jul 05, 2010 | Sony KP-57WS500 57" Rear Projection...
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Red lines on Sony KP51HW40 Rear projection TV
Yeah, seen that more times than I shoulda in the last 4 years. The red picture tube has a cathode to heater short. That means it's no good. That red picture tube is no longer availible. But all is not lost. There is a company that rebuilds those tubes reasonably. Most reputable tv shops will know this. The ones I've done cost around $450 out the door. One minor hitch is that with all the shipping involved the job usually takes about three weeks. That can be expidited but then the price goes up.
May 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony model kp51ws500
Yes common problem it seems with these. I can help you get the set working but this fix only prolongs the inevitable so I'm told. (more about that at the bottom) Please read entire posting before starting. You will need to take off the front panel, there are 2 screws towards the bottom on each side behind little pop out plugs. Once those are out take off the panel (pull from bottom, sometimes the round clips at the top come off, either glue them back on the panel or leave them out). There are wires attached to the panel, you can either unhook them or just take them out of the "twist tie" holders and move the panel out of the way to the left. You will now see a thin panel. Remove this one also. Once that is off you will see the bottoms of the 3 glass tubes and on the "floor" of the set there is a group of 6 small knobs. This is called the focus block. Each row of 3 knobs are labeled either screen or focus, also, there should be 3 letters R G B (Red Green Blue). (We won't be adjusting the focus knobs).You will need to adjust the Blue screen knob (on my set it was the bottom left knob). If the set will stay on for a little bit you can adjust it with it on. Once you have found the correct knob (don't worry about the white paint) turn the set on, once you see the picture slowly turn the blue screen knob counter clockwise until the blue diagonal disappear. Be careful not to turn this knob too fast while the set is on. Keep in mind, it may take a little bit to break off the paint. You will see the screen turn back to normal as you turn the knob. Adjust it just until the lines disappear This should solve your problem. If the set won't stay on, with it off turn the knob about 1/8 turn counter clockwise then turn the set on. Once it is on you can fine tune it. Adjust it just until the lines fade out of sight. (You may have to adjust back the other way until the lines show up and then back it off again). Remember to turn the knob slowly. I have heard people getting charged a lot of money for this. I was also told that this is compensating for a dying component(s) all I know it has bought me at least a year. I also read that someone has gotten several years out of there set w/o repair just by doing this adjustment whenever its needed. (once the lines start presenting themselves). I can't see spending big money on these sets when you could put it towards a new set so I will keep it going for free as long as I can. I hope this works out for you. I'm tired of typing so good luck and post if you need any more help. BTW this adjustment works if this symptom presents itself in green or red also. Just substitute the blue knob to the applicable color. Now go put your TV back together :)
Feb 24, 2009 | Sony KP-51WS500 51" Rear Projection...
Further assistance needed
I just replied you and here once again...
Please pull front speaker grill and find focus block, fixed at corner having 6 control knobs on it.
Find Blue Screen control knob there.
Put your TV in AV mode to get dark screen and just press Display button on remote to have AV display.
Now slightly rotate control knobs counter clock wise until thin lines (retrace) disappear. Job is done and put back speaker grill, press display button again to disappear screen display.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
F231 problem
NO SIR
In this fault fuse dosen"t blow further
any way you replaceFuse by same (oldone)Rating.
for shading proble
clean inside RED/GREEN/BLUE/ CARTHODE RAY UNIT BY SOFT CLOTH (DO NOT USE ANY SOLUTION"S)
AFTER THAT YOU GOT A GOOD QUALITY PICTURE.
OK
WISH YOUALL THE BEST.
Nov 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Hitachi Big Screen TV 46 inch Problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 06, 2007 | Hitachi 46BX01B 46" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
193 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
