Question about Toshiba Computers & Internet
Toshiba satelite P105 laptop pc problem: overheats and shuts down automatically. while in use. What are the causes of overheating?
  • Toshiba Master
  • 32,281 Answers
Normal 0 When a CPU chip overheats it shuts down (thermal overload) and won't boot up again until it has cooled down. If this problem is not fixed, then eventually the CPU chip will fail. This fault is either a faulty fan or the fan and heat sink assembly is clogged with dust. Please click on this link and follow my instructions to fix :-
http://www.fixya.com/support/r5959377-overheating_computer
Posted on Oct 16, 2010
I have a Toshiba satelite p105-s9337 the laptop will start up and after 10min it will shut off. I cannot start it again for about 1 hour and the cycle is repeated. I can take the batter out and the problem...
That sounds like a heat issue. Open the back panels and you will see the fan, turn on the laptop and see if the fan spins. If it does, its usually clogged. You will need to pull out the fan assembly and peel off the fluff that isn't visible on the end of the copper heatsink.
Once reassembled, the laptop may run much better. You can buy a laptop stand that assists the fans by blowing cool air inside.
You may find blowing out the dust with a can of air, or from an air hose or tyre inflater at your local garage.
Jul 23, 2011 | Toshiba Satellite A105 Notebook
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
Toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Aug 18, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
How to reset BIOS in dead Toshiba Satelite P105-S6177
go to ru and type msconfig.Then u'll see a window , der goto boot.ini and delete one os.and restart the system
Jun 24, 2009 | Toshiba Satellite P105-S6177 Notebook
Need to know how to dismantle Toshiba Satellite P100 to clean and check heatsink and fans, unit keeps overheating and shutting down thanks gene
Here is Toshiba Satellite P105 (which is the same as P100) disassembly guide.
Just follow instructions by scrolling down, then go to page 2, 3, ...
Jun 10, 2009 | Toshiba Satellite P100 Notebook
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
Jun 01, 2009 | HP Pavilion DV5-1000US Laptop
When i play sims 2 it always hang then my pc will shut down automatically. the spec of the games are compatible to my loptop what will i do?
There is a problem of overheating. Maybe the specs are almost exactly the same as the game requirements. So the PC still has to work hard. This causes overheating, which should not happen if it is even perfectly compatible.
So, this means that something is causing the computer to overheat. Firstly, shut down any open background programs. Also, see that the laptop vents are not blocked by any thing around. Remember to dust the heatsinks, fans and the casing. Also, the keyboard and main vents. If you can, vacuum it all and open up the casing to be sure that all the gunk is out.
Jan 30, 2009 | Toshiba Satellite A75-S231 Notebook
My satelite a100 laptop overheats and shuts down
Your cpu cooling fan may need to be replaced.
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
