Question about Miele CVA610
Miele coffee system and dishwasher
Just bought a house with a cva 610-1 model # How old is it and what does it retail for?
It also has a touchtronic ultra dishwasher HG 01
How old are they and what do they retail for?
We bought ours at the end of the model year, Aug 2003, so that should make it introduced in 2002. Typically available for 2-2.5K as backsplash says. Not sure about the -1; ours is just CVA610. A couple years later they came out with the automatic foaming feature with a milk reservoir, selling now for similar prices versus the 610 which has a steaming nozzle. It is essential you keep them decalcified, especially if you have hard water.
We bought the dishwasher at the same time, touchtronic G894SC: best dishwasher I've seen or used! A keeper, no problems.
Posted on Sep 24, 2008
When it came out it retailed for 2,500$
Posted on Aug 14, 2008
Miele CVA5065 coffee machine has fault 77
I am not familiar with a CVA 5065 - but most of the other Miele coffee systems fault 77 is the ceramic valve initialization or the switch (S51) associated with it.
Apr 20, 2014 | Miele Coffee Makers & Espresso Machines
I have misplaced my instruction manual and information on my Miele coffee machine. CVA 610. Could you please send me the manual. I have moved into a different house and the eletrician is installing. I...
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa
Sep 08, 2010 | Miele CVA610
Miele CVA 610 coffee system says "water system fault" can I fix myself?
Hi I,am not 100% familiar with this model but the machine thinks the is a leak. Remove water tank the should be a hole visible under tank place finger in hole and check for water. If so remove water with syringe etc. Leak most likely cause tank incorrectly fitted or faulty seal on tank. If water tank seal OK, Remove water with syringe etc appliance will work. As a precaution remove lid and run you should be able to see any leaks. If not look for white stains on components. If no leaks or stains found it's was most likely tank incorrectly fitted.
Aug 22, 2010 | Miele CVA4070 Coffee Maker
Drain Hose Replacement
drain hoses are quite standard. the rubber spigot at each end can be different sizes and some have a right angle bend at the end. suggest you take out the old hose and take it along to match up - easiest way
Aug 28, 2008 | Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele CVA610 Logo
226 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
