Question about Acer Aspire T310 PC Desktop
MY PC ACER ASPIRE T310 ONCE I SWITCH ON IT DISPLAY NO SIGNAL, I CHEK IT ON PROCESSOR,RAM,VGA N MOTHERBOARD ARE OK. What cud b the problem? I need a solution.
  • 386 Answers
Hi Good day!!! check the both ends of your VGA cable maybe it is not connected properly or it loosen up. Hope in works now!! if not just reply to me and i will assist you more...
Regards
JR
Posted on Oct 16, 2010
On switching the computer on monitor shows no signal. the cables are connected properly
1) Computer unplugged from power, computer on a table, computer case open.
Use a can of compressed air for computers, and clean out the inside of the computer, and it's Power Supply.
[Viewing the front of the computer, the Left Side Panel removes. Two thumbscrews in the rear, slide the panel towards the rear of the computer]
2) Observe Anti-Static Precautions.
Your body carries Static electricity.
Static WILL fry out (Short Circuit) hardware components in a computer. (Processor, Ram Memory, etc.)
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again.
3) Remove the Ram Memory modules. (Ram memory 'sticks')
Clean the gold plated contact pins on the bottom of the ram memory module, with a pencil eraser.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
You can click on the photo to enlarge. You can enlarge twice.
Rub the eraser on each contact up, and down. You don't have to scrub it with the eraser, just use medium pressure.
(Both sides. All contacts. Just takes a few minutes.
The Acer Aspire T310 uses DDR Sdram ram memory. Just like shown in the link example above.
There are 184 contact pins. 92 on each side)
Once you have finished cleaning use air to remove the eraser dust.
If you have a can of compressed air for computers available, use it.
If not air pressure from your mouth will be sufficient.
Still no?
Then I suggest you have a bad Power Supply.
Weak voltage power rail.
(There are three main power rails for the power supply used in that Acer.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail.
All are DC voltage.
Two D cell flashlight batteries produce 3 Volts DC)
With a Power Supply having a weak voltage power rail, there is enough power to light LED lights, maybe spin fans, but not enough to turn the Processor on.
A) ALL of the LED lights combined use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is.
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/ACF31F.pdf
Copy the above link, paste it in your address bar, press the Enter key.
It's the Service Manual in PDF file form, from Acer Support for the Acer Aspire T310.
Oct 10, 2010 | Acer Aspire T310 PC Desktop
ACER ASPIRE T310-3970 WHAT PROCESSOR CAN I UPGRADE TO ?
you can upgrade to intel i5 processor since this system supports up to 2MB RAM...
Aug 29, 2010 | Acer Aspire T310 PC Desktop
Can't turn on just hang
if u changed the BIOS battery on the motherboard and havnt re installed the BIOS it Wont Work.....
Mar 24, 2010 | Acer Aspire T310 PC Desktop
Acer Aspire PC T310 boot up problem
try bios reset, all common problems occur after a major power outage or power spikes... try resetting the bios and it should work fine, if not try replacing the video card and start from there...
Jan 02, 2010 | Acer Aspire T310 PC Desktop
Acer Aspire T310, no signal to monitor?
Check and make sure the monitor is good by using another computer on that monitor. If that is good then the cable is good. Are you getting any video display at all? Does it start and then lose signal or no signal at all? Is there on board video or a video card installed or both? If there is both have you tried both vga connections? If there is a video card installed make sure that it has not come loose and is fully seated. Does the computer have lights when it boots up....Hard drive activity ect?
Sep 08, 2009 | Acer Aspire T310 PC Desktop
No display when using bulit in graphic card or AGP grahic card
ok!
first,
check your
motherboard
if all pin is conected properly
check your power suplly
try to replace the power supply
is not necessary to replace the power supply with the original powersupply
replace with standart 350 watt power supply (or higher)
then if the problem is still exsist
check *********** board
try to replace the motherboard
replace it with
any socket 478 motherboard
if nothing change
try to replace the RAM module
replace it with any DDR RAM module
then the last one
if nothing change
you must replace your processor
with an 478 socket processor
note: replace the component with borrowed
you  can borrow the component from your friends or anyone
then if your computer is showing display again
you can buy the component from ebay
here original specs of your computer:
Specifications - Aspire T310
Processor
Intel® P4 Processor with 400/533/800FSB (depending on processor)
Intel® Celeron Processor with 400FSB
Cache
128KB or 256KB (dependent on processor)
Memory
128MB DDR SDRAM PC2100/PC2700/PC3200 expandable up to 2GB
Chipset
SiS 661FX Northbridge Controller,
SiS964L Southbridge Controller
Expansion Slots
3 PCI v2.2 slots
1 AGP slot 4X/8X
Audio
Integrated Realtek ALC655 audio codec (SoundBlaster® Compatible AC97 Audio Codec)
Speakers (selected models)
selected models
Video
Integrated SiS 661FXVGA,
Storage
3.5" 1.44MB Floppy Disk Drive
52X CD-ROM, CD-RW or DVD-ROM (selected models)
20GB-80GB Hard Disk Drive (selected models)
Modem
56K V.90 (selected models)
Networking
Integrated Realtek RTL8100C 10/100 Base T
Ports
1 PS2 Mouse port, 1 PS2 Keyboard port, 2 USB Front, 4 USB Rear, 1 Parallel, 1 serial , 1 VGA, 1 game/midi, 1 RJ45, 5 audio (2 front, 3 rear)
Power Supply
Industry Standard 230 Watt
Chassis
14.2" 360mm) H x 7.1" (180mm) W x 16.5" (420mm) D
Operating System
Windows XP Home
Windows XP Professional
Windows 2000 Professional
Warranty
1-year Mail-in/carry-in warranty, Technical support for first year, available 8a.m. to 8p.m. CST Monday through Saturday (hardware only), 90 day software support. Call 1-254-298-4696
Specifications are subject to change without notice. Warranty covers only Acer purchased parts that are listed as supported and serviced. Please see limited product warranty for full details. Acer, the Acer logo, AcerPower, AcerAcros, AcerEntra, AcerAspire. Aspire by Acer, and Veriton are registered trademarks of the Acer America Corporation and Acer, Inc. The Intel Inside logo and Pentium are registered trademarks of Intel Corporation. Microsoft, Windows, Windows 95, and Windows 98 are registered trademarks of Microsoft Corporation. All other brands and products names are trademarks or registered trademarks of their respective companies.
Jan 24, 2009 | Acer Aspire T310 PC Desktop
Acer aspire t310 compatibility
Hi, it seems you are limited to the Pentium 4 series of processors with this computer. This is the corresponding page of your systems specifications: http://www.acersupport.com/desktop/aspire/html/as_t310_specs.html
Apr 29, 2008 | Acer Aspire T310 PC Desktop
Acer Aspire T310 PC Desktop Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
